Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-12-2006, 06:31 PM
rahl rahl is offline
Me again
once again another problem. since i replaced my heater motor ive been having some hesitation problems at around 55-60 km/h and when turning a corner. could this be something with my carburator? i had to remove the top part to remove the heater motor. also a smell of gas now when car is idle... believe its from the exhaust but still pretty strong smell inside the truck when starting it and in idle. thanks
Old 03-12-2006, 06:45 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Me again
With the engine cold lift the hood and start the car. Look at all fuel connections for a leak. If you smell gas inside the car then there is free gas inside the engine compartment which could cause a fire. If you find a leak then get it fixed ASAP!
Old 03-12-2006, 10:05 PM
Re: Me again
ok well no smell under the hood. i think i may have backed into my exhaust which would have let it into the truck itself to smell that strong. took a look and everything seems to be in working order under the hood without a smell.
