Old 03-12-2006, 05:25 PM
89civic_sedan 89civic_sedan is offline
Engine problems
I had came home from school and on the way i herd some backfireing so when i got home i left it running poped the hood and looked at it. It got worse so i decided to back it in cause the old ladie across the street will call the police on me for it be so loud. So i turned it around my friend came up here and was helping me. So i went to go crank it back up and all it did was turn over. Come to find out this dummy swaped the sparkplug wires and now all it dose is turn over i dont know what to do. Can someone please help??
Old 03-12-2006, 06:18 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Engine problems
Old 03-12-2006, 06:25 PM
Re: Engine problems
Ok let me go try.
Old 03-12-2006, 06:34 PM
Re: Engine problems
after i tried it all it dose now is turn over about 4 or 5 times it will catch or sound like its trieng to crank but then keeps turning over. Its like it has no fire but i just changed the spark plugs in it.
Old 03-12-2006, 06:41 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Engine problems
Double check the wires, make sure that your getting the orientation of the distributor in the picture right...then make sure that the wires are firmly on the plugs...
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-12-2006, 06:55 PM
Re: Engine problems
I did that and nothing worked. My friend, the dummy, took the spark plug wire completly out the spark plug hole and i tried to crank it up thats when it messed up. I think it has something to do with the rotary button.
Old 03-12-2006, 06:57 PM
FrodoGT's Avatar
Re: Engine problems
Im not totally sure, but I think that it could burn out your coil doing that...Id wait for a second opinion...
Current project:
Rio Red 91 hatch.
Old 03-12-2006, 07:01 PM
Re: Engine problems
OK ill just wait on another person to tell me but thanks
Old 03-18-2006, 03:38 PM
Re: Engine problems
Well i decided to work on my car so i bought new spark plugs..Put them in and it crunk up but it idled at 500 for about 3 seconds then it would go dead and if i push the gas all the way to the floor it goes up to 2grand then idles back down then shuts off..Can someone help me?
Old 03-18-2006, 09:38 PM
ElbertR ElbertR is offline
Re: Engine problems
Try replacing the ignition cables, distributor cap and rotor.
Is your check engine light on? And code flashes on the ECU?
91 Civic STD HB. Over 280,000 miles on car, estimate about 100,000 miles on engine (D15B1). Original 4-Speed Tranny swapped for DX 5-Speed. Power doors, remote entry, remote hatch popper, power windows. MPFI swap completed!
Old 03-19-2006, 03:18 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
Re: Engine problems
i had this same priblem on my d15b it turns out it was the tachometer wire that i had installed the day before. i had to pump the gas pedal to keep it running. good luck. and like these guys said check it out again
Old 03-19-2006, 07:48 AM
Re: Engine problems
Well the engine light comes on and flashes 3 times. Ill replace that other stuff when i get time.
Old 03-19-2006, 08:39 AM
Re: Engine problems
You would have to lift up the carpet from by the front passenger feet and see if the ECU ('electonic control unit') gives you any red flashes through the small window. If so, count the number of flashes, it will point to the source of the problem.
Old 03-20-2006, 02:54 PM
Re: Engine problems
Yea i pulled the carpet up and looked at that red LED flashing light and it flashed 3 times..Where is the ignition cable or tachometer wire located at?
Old 03-20-2006, 03:12 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Engine problems
Code 3 is for the MAP (Manifold Absolute Pressure) sensor.
Map sensor is to the left of the Dashpot Control Solenoid Valve on the firewall. Check vaccum lines going to it. Reset your computer by pulling the 10a hazard fuse and 15a ecu fuse in the under hood fuse box.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
