Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-12-2006, 06:12 PM
GirlBear's Avatar
GirlBear GirlBear is offline
Where is the crankshaft position sensor
my buddy's car just wont start. its a 1994 sl1 manual drive. we changed plugs wires pcv valve battery is good. cranks but no start. if we let it sit for hours then turn the key, it pops from around the intae behind the valve cover. ne 1 have an answer
http://jowulf.deviantart.com/
Old 03-13-2006, 12:21 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: Where is the crankshaft position sensor
ok well to answer the cps location, it is on the backside of the engine pretty much in back of the starter. its held on by 1 bolt.
now your problem could be a fuel pump, ignition module, coils, once again loads of things. need to test all fuses and relays and check voltage to everything including injector pulse. check for spark. once you start to diagnose it more, i could help more. also it could very well be the coolant sensor, rare but it can cause the car to not start.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 03-13-2006, 04:24 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
check fuel, spark, intake, exhaust, and compression.
the poping noise my be backfiring in the intake, a sign of a clogged exhaust, most likey a bad cat. remove O2 sensor and crank to confirm.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
