Old 03-12-2006, 04:42 PM
94 civic ex 94 civic ex is offline
clutch problem. please help.
ok, i just recently swaped a used tranny into my 94 civic ex because mine went out, i bought a new flywheel and clutch kit. it is in and works but the clutch pedal is just not right. it is really soft and engages the clutch about a inch off the floor.
I have bleed the hyd. system 4 times and i hope that i just still have air in my lines but i cant get it out. i have checked for leaks and found none, there is no fuild under the clutch pedal and i looked thoughout this forum and tried bleeding it with it running and a person inside the car holding the clutch pedal down while i open the vent on the slave.
i tried gravity bleeding it and that didnt work.
i talked to a local mechanic and he said unbolt the slave cylinder and tip the rod down and pump it till the air came out, yes air came out and when it stopped i put the slave back on but im still left with a spongy clutch pedal.
help please.
Old 03-14-2006, 01:19 AM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: clutch problem. please help.
put a new slave and master they are cheap and a good ensurase that you wont have any problems in the future by bending the fork. you can check the slave boot and see if its wet thats a sign its bad but the master its not that easy the seal can be broken internally and not see any fluid leaking.
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
