Old 03-12-2006, 02:09 PM
hondacivicracer21 hondacivicracer21 is offline
Angry Surging idel
My cars rpms surge no matter how warm the engin gets. The only time it stops surging is when i get the rpms past 4000. even when i drive under 4000 the car will drive funny, the speed will go from fast to slow fast slow and so on. And I am not sure what could be causing this. could it be the TPS (throttle position sensor) or just the throttel body. or maby a injector is stuck open. i also think i might have a bad o2 sensor (because yes, the check engin light is on). is it ok to drive it as long as i run it on higher rpms? some one please help. Thanks
Old 03-14-2006, 12:13 AM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
Re: Surging idel
on the bottom of your throttle bogy there i a valve assembly. it is called a fast spsed idle valve this is most likely you problem. it is very common to go on hondas.just get one from your local honda dealer they will most likely have it in stock and dont forget the throttle body gasket.
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
Old 03-14-2006, 05:53 PM
Re: Surging idel
what exacy does that do and how hard is it to replace
Old 04-03-2006, 01:40 AM
Bruce Hunt Bruce Hunt is offline
Re: Surging idel
I put an article out about this on this forum. Now, you have a check engine light on and problems. Find the code on the ECU. Then you will have something to work with. Don't go jumping around until you know the code. Finding it is free. I am not going to explain how to do it. There are plenty of sights around that explain the shorting of the ecu clip and counting the light flashes to reveal the code(s). I have found that there are many reasons for the surging. Have you have anything done to the engine recently or so? I found that problem was related to the intake manifold and a leak of air into the mainifold at the gasket. The extra air causes the ecu to try and compensate with fuel for the air. The result is the engine surging. There are other reasons why the engine surges. Get the code. I bought a OBD2 scanner on ebay for $35. Great investment on my part. It reads any car 1996 or newer. Let me know what you find out.
If I was able to help you, that made my day; if you offered assistance to me, I thank you so very much! Either way, have a great day! Now own 4 Accords and 2 Civics. Love Honda!
