Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-11-2006, 11:11 PM
adrenalinjunky99 adrenalinjunky99 is offline
please help asap suspension question
hi i recently lowered my car with new springs how ever on one of them the front driver the center lock nut on the shock i put the nut up side down and its like half way down so now it wont come off for shit i was thinking maybe i can cut it off? because i dont want to buy a new shock plus the spring and everything is on it so i would have to cut the shock or something to get the spring off, is there a good way to cut a nut? it still rides fine and everything it just makes a wierd noise, something you dont want to hear while your driving lol a scary noise, anyone with any ideas please help asap, thanks
Old 03-12-2006, 12:53 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: please help asap suspension question
How "stuck" is it? do you have an impact? I wouldn't cut it unless absolutely necessary, if you do cut you will need to retap the threads.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-12-2006, 12:57 AM
alphalanos alphalanos is offline
Even if he were able to remove it without cutting, he would still need to retap the threads. Sounds like hes going to have to cut it. That would do the least damage.
96 EJ6. Future home of boosted B18C1.
Old 03-12-2006, 01:15 AM
kjewer1 kjewer1 is offline
AF - Advisor
Cut notches on 3 or 4 sides of the nut as close to the threads as you can get without touching them, assuing you have a die grinder or dremel with cutoff wheel. That will usually let the nut expand a bit and loosen up the pressure enough to allow it to be worked off. If you can't clean up the threads enough to get another nut on, and there is enough good thread at the top, cut a thickwall hollow dowel pin or machine bushing down to act as a spacer allowing the nut to tighten while it is still on the upper threads to avoid having to shitcan that shock.
Also, putting a nut on upside down won't cause this problem, something else was going on there.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-12-2006, 04:45 AM
yeah i dont know what went wrong, it was just getting super hard to tighten and then i noticed it was upside down now matter what it wont budge espescially wint i have to make sure the rod doesnt spin while trying to unscrew the nut, what can i use to cut it? im starting to think a bolt cutter, not sure what to use, yeah i figured i would have to re-tap it, this sucks, thanks for all the input and help tho guys i appreciate it
Old 03-12-2006, 05:08 AM
AF - Advisor
I would use a thin cutoff wheel in a dremel or die grinder.
Kevin Jewer
Old 03-12-2006, 01:02 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Ooh, sounds to me like you cross threaded it. Did you impact it on? Yeah, I would try and cut it off like Kevin said. I wouldnt use a lock cutter, find someone with a dremmel or rotozip.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-12-2006, 07:40 PM
hey i got it off and put a new one on no need for re-tap either i used a grinder grinded it down a bit then it allowed me to unscrew it got a new bolt stuck it on there, perfect fit, i was trying to use a dremel but the cut offs kept breaking, thanks again
