Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-11-2006, 09:46 PM
TeamRedLine23's Avatar
TeamRedLine23 TeamRedLine23 is offline
Send a message via AIM to TeamRedLine23
e-brake light
the only thing that is wrong with the car is that e-brake light is on all the time, even when the e-brake lever is down. any ideas? other then that the car is perfect.
1997 Eclipse GS-T
Performance modification:-evo3 16g-K&N Intake-HKS SSQV b.o.v vented-2.5'' Dejon tool blow thru upper and lower-Dejon large smic-GM MAF-MAF Translator-HKS 3" Carbon Fiber Titanium TBE-stock fuel rail-Walbro 190 fuel pump-PE 650cc injectors-Accel Thundersport wires-NGK series 7 spark plugs-1g intake mani/head-
Interior Modification:-Autometer Boost Gauge
http://www.cardomain.com/id/xTeamRedLine23x
Old 03-12-2006, 09:37 AM
SLoe's Avatar
SLoe SLoe is offline
Re: e-brake light
The light is switch operated, so find the switch and see if it is being actuated. Check the continuity also, the switch may be shorted.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-12-2006, 10:28 AM
Re: e-brake light
ok thanks
1997 Eclipse GS-T
