Old 03-11-2006, 05:54 PM
SkylineMan32
Guest
Posts: n/a
Lotus Super 7
This is a Tamiya Lotus Super 7, I converted it to newer Caterham specs by installing a Ford ZETEC motor.
This particular one is actually the SVT variant. The conversion is relatively simple, you hot knife the transmission off of the old Cosworth motor, then remove the FWD transmission off the ZETEC. Using a dremel remove the tab off the block that holds on the transmission. Next remove the oil pan and using a dremel smooth that surface, also remove the Focus motor mounts. The Cosworth carbuerators fit nicely on the ZETEC head, however the very end of the flange hangs off the head and needs to be removed. Also the chassis brace that comes off of the fire wall has to be cut off. The driveshaft has to be cut down. Then remove mouning tabs from the bottom of the transmission. If you flatten the bottom of the tranny it can be glued to the floor. All of this with-out and major modifications. The hood does need to be scooped, and I put in a side duct so I could use the horns on the carbs. The stock Focus header will work as well you just need to cut it where it begins to turn down and then adapt it to the sidepipe with solder or sprue. I know this is a lot of writing but it is a lot simple than most motor swaps.
The color is actually left over paint from my Fiat. I am using stock rims because nothing else that I had would fit.
Old 03-11-2006, 06:59 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Lotus Super 7
mmm zetec..
that motor looks big in there
if you really want to convert it to caterham specs you'd have to remove the vct on the motor
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 03-11-2006, 07:04 PM
SkylineMan32
Guest
Posts: n/a
Re: Lotus Super 7
what is vtc? BTW it is just a psuedo conversion, what I meant was it was based on reality. I did this car because I had a ZETEC around, and I have seen 7's with ZETECs, its not like I put an RB26 or LS1, or L88 for that matter in there.
Old 03-11-2006, 07:20 PM
pre98zetec's Avatar
Re: Lotus Super 7
vct is variable cam timing, offered on the svt zetec (non-svt focus are non-vct zetecs).. ive never seen a zetec w/ vct used in a caterham. it was always pre-98 Contour zetecs (same one in my car) or non-svt focus zetecs..
Good conversion though. I'd like to build one someday.
-Josh-
Old 03-11-2006, 07:33 PM
G-man422's Avatar
G-man422 G-man422 is offline
Re: Lotus Super 7
Woah! nice, that color goes well w/ the car.
Old 03-11-2006, 08:02 PM
SkylineMan32
Guest
Posts: n/a
Re: Lotus Super 7
Thanks for the nice comments guys
Old 03-11-2006, 09:13 PM
675datsun's Avatar
675datsun 675datsun is offline
Re: Lotus Super 7
Great idea!
Old 03-11-2006, 09:31 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Lotus Super 7
Hey, what kits have ZETEC's? I've got a 7 in my stash, and I've been hoping to find a ZETEC to stuff into it. I've been looking, but appearently in the wrong places- this is the first I've heard of a ZETEC in 1/24.
PHOTOBUCKET SUCKS
Old 03-11-2006, 09:37 PM
pre98zetec's Avatar
Re: Lotus Super 7
revell has a Focus SVT with a full detail Zetec.
-Josh-
Old 03-11-2006, 09:49 PM
SkylineMan32
Guest
Posts: n/a
Re: Lotus Super 7
Yeah thats where I got mine.
Old 03-12-2006, 11:01 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
Re: Lotus Super 7
Very cool. Can't go wrong with a blue Seven... - Mark
Old 03-12-2006, 01:10 PM
KTem's Avatar
KTem KTem is offline
Re: Lotus Super 7
Looks cool I may build one with a BMW i6 engine in it... wooo! Performance!
Old 03-17-2006, 02:09 PM
SkylineMan32
Guest
Posts: n/a
Re: Lotus Super 7
They were fun with the 85HP cosworth a ZETEC or especially BMW I-6 would be insane. This car is coming along and pics will be up soon.
