Hi,
This is the first time here and I am in need of help. A common problem with the 2002-2003 Chevy Impala seems to be a cracked Intake Manifold Gasket. This is what happened to my 03 Impala. Manufactured 12/02. I am replacing the Lower Intake Manifold gaskets myself. There are two gaskets for each side. I had to remove the Push Rods to get the gasket off. I ONLY LOOSENED the Rocker Arms to remove the rods. I kept each rod in line as I took them off, so I do have each rod back in its orginal position. My problem is: I have hand tighten the Rocker Arm bolts, and I am unsure the torque specification for each bolt? What is the torque lbs. for each rocker arm? If someone can help me with that. And is there anything I should be scared of, like aligning the ROCKER arms or lubricating the arms?????? PLEASE any help would be appreciated. Once the arms are secure I can apply the seal and PUT EVERYTHING BACK. thanks. |
Re: 02-03 Impala need torque
valve rocker arm bolts.
3.8 - 11ft/lbs http://impalaauthority.com/Valve_Roc...llation_38.pdf 3.4 - 24ft/lbs http://impalaauthority.com/Valve_Roc...llation_34.pdf |
