Old 03-11-2006, 01:27 PM
stretch_tr stretch_tr is offline
Arrow loading up
hi guys new here, so like to ask for some help. i have a 92. 1500 with a 4.3 in i.t and i can't get no power out of it. it smokes black and loads up bad. i put a new esm, tbi, map. and still runs bad. please help before i drive it into a brick wall
Old 03-11-2006, 02:53 PM
Hammer59 Hammer59 is offline
Re: loading up
Check the fuel pressure, it should be 9 to 13 psi. It could be a bad injector also.
If you need injectors, get back to me. Also did you set the tps when you put the new tbi on it?
Old 03-11-2006, 08:53 PM
Re: loading up
Take your air cleaner and spacer ring off. Then watch the spay pattern of the injectors. You should have a even pattern, If it dribbles out you have a bad injector.
