Old 03-11-2006, 11:43 AM
draybook draybook is offline
My compression results
Yeah, they were terrible and I'm hoping it's not the rings. They were as follows:
90-60-5(barely moved)-30.
Old 03-11-2006, 09:14 PM
duffman868 duffman868 is offline
Re: My compression results
a leak down would tell you what it is
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 03-11-2006, 10:57 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
OUCH, do you even HAVE a number 3 cylinder lol!
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-11-2006, 11:09 PM
Yeah, I'm not sure what the leakdown is but I'm going to try to place a little bit of oil in each cylinder and see if the compression goes up.
Old 03-11-2006, 11:20 PM
a leak down is when you put pressurized air in the cylinders. then listen for the leak. then depending where the leak is tells you what to check first
Old 03-12-2006, 01:56 AM
Hybrid1990crx's Avatar
im sure there has to be some ring damage. that'd probably be a cheaper fix then the head. you compression should be around 200ish.
Old 03-12-2006, 06:49 AM
Reall? The rings would be cheaper than the head?
Old 03-12-2006, 04:26 PM
FrodoGT's Avatar
Hell yeah tey would, I think for a 4 cylinder it shouldnt be more than $50, I havent looked but for my friends camaro it was 49 at NAPA.
Current project:
Rio Red 91 hatch.
Old 03-12-2006, 04:45 PM
I was under the impression that it would be cheaper and easier to just replace the head.
Old 03-12-2006, 05:12 PM
FrodoGT's Avatar
I dunno what engine you have but I just lookjed it up for a 91 civic at 66.49...
Current project:
Rio Red 91 hatch.
Old 03-12-2006, 05:21 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
idi you break a timing belt and just replace the belt? them numbers are crazy low. what happend. last time i saw numbers that low it was bent valves.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-12-2006, 05:33 PM
FrodoGT's Avatar
I would think youd have to have like no rings for compression that bad, so I would have to agree in saying, wtf? You must have one messed up set of valves, possibly in addition to the rings.
Current project:
Rio Red 91 hatch.
Old 03-12-2006, 09:30 PM
It's a 1988 Civic DX, 1.5L. Yeah, I know there's something wrong with those numbers. I'm hoping it's just the head, a nice quick fix.
Old 03-12-2006, 10:04 PM
FrodoGT's Avatar
Hope for the best, plan for the worst...
Current project:
Rio Red 91 hatch.
Old 03-13-2006, 12:56 AM
well a used dx head will probably go for extremly cheap. you can also try autohausaz.com for rings and bearings
