Old 03-11-2006, 11:32 AM
hnc3 hnc3 is offline
Cd stuck in player
CD stuck in Player (1998 4Runner)
I have a 1998 4Runner with a CD stuck in the player (it is not a changer). I believe there is an additional problem. The player seems to act is if there is no CD in the changer and no power but there is power to the radio and tape player. When I tried to fish it out with a pair of needle nose pilars I found a metal bar ubstrucking my path. I can see the CD but it seemed to be down in the player. I don't seem to see any way off opening up the player with out removing the console. Any help would be appreciated.
Thank you in advance
hnc3
Old 03-11-2006, 06:25 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Cd stuck in player
look around and see if there is a small button that's a reset
Old 03-11-2006, 07:58 PM
I did and no, I did not see anything. I was thinking the same thing but no luck. Thanks for the reply. Any other ideas ????
Thank you.
hnc3
Old 03-12-2006, 12:53 AM
Audio Guy
try just diconnecting the negative terminal of the battery for about 5 minutes, I know it resets all the radio stations.
Old 03-12-2006, 11:02 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
If that doesn't work then you might have to bite the bullett and remove the cd player from the dash and open it up to get the cd out and then replace it with an aftermarket cd player. Pretty expensive cd but if you plan on listening to any in the future then that's what will probably have to happen.
Old 03-12-2006, 01:31 PM
IT WORKED !!!!!!!!!!!!! I removed the negitive side of the battery and that did it. How simple.
Thank you very much for the advise !!!!!!!!!!!
hnc3
Old 03-12-2006, 06:23 PM
Audio Guy
good, cuz I was out of ideas that didn't involve removing the radio etc ...
Old 03-17-2006, 03:23 PM
chronicgrl_420's Avatar
chronicgrl_420 chronicgrl_420 is offline
I have the same problem with my cd player sometimes, but i figured out that if i stick a driver license or some sort of card, and it will put the cd back in place and it will pop out when u press the eject. Dont know if that woulda work for your but it always worked for mine
