305 TPI on a 350
I want to put a 305 TPI unit out of a 1986 Z28 on a 1971 350 4-bolt with 041 heads, 1.94/1.50 valves. I need to know what I need to do to make this work, as far as I know I will be installing 21 lb injectors, a 58 mm throttle body, and have a custom chip burnt. Has anyone done this before and can anyone help me figure out what camshaft to use and if there is anything else I need to do. Thank you, Brett
Re: 305 TPI on a 350
your gonna figure out how to mount the intake manifold because I belive the bolt pattern is different. But between the 305 and 350 tpi system there is no difference. They are exactly the same. 21lb injectors will work but you would be better off going to at least 24lb depending on what parts the rest of the motor have.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
