Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 03-11-2006, 09:46 AM
ongi ongi is offline
car dont start in bad weather
when ever there is bad weather, like rain and snow and when ever its really humid my car wound freaking start. When i finally start it after trieng like a million times the rpm starts to fluctuate and goes below 1000 and my car shuts down again. One time i was goin to my college and i went through a puddle of water and my car stopped. the car cranks but woont start. i recently spend like 3500 to fix the damn car
Old 03-24-2006, 04:59 PM
WaskewyWabbitOwnew's Avatar
WaskewyWabbitOwnew WaskewyWabbitOwnew is offline
Re: car dont start in bad weather
If your distributor cap was cracked (even micro-cracks [when old]), that would do it--getting water down in there.
Old 03-25-2006, 11:03 AM
zeek1403 zeek1403 is offline
It could also be your ignition coil. The coil sits on the drivers side and mounted on the back wall. To test it, pour a little water on it while the car is running. If the car stalls, then it would be your ignition coil.
Old 03-29-2006, 01:24 AM
thanks for the reply, but can you tell me the exact location of the ignition coil, thanks
Old 03-29-2006, 01:34 AM
and can u tell me if i wanna swap a vr6 with a 5spd manual in my jetta how much would it cost me
Old 03-29-2006, 03:35 PM
The coil is on the firewall, near the middle--like, under the driver's windshield wiper. Open the hood, and look for (mine's black) a cylindrical object mounted on the back wall--there's a fat (spark-plug-like) wire directly from the middle of the distributer cap to it.
______
/ /__| \__
(O)----(O)--/
Old 03-30-2006, 09:30 AM
yo man thanks ALOT, it is the ignition coil. i poured some water on it and now its not starting. Now can u tell me how to replace it thanks
Old 03-30-2006, 11:22 AM
i just found out that there are crackes in the plastic cover of the ignition coil, so i applied some bathroom sealent on it, ol would that be any good
Old 03-30-2006, 07:13 PM
stuzman stuzman is offline
Who knows? I always replace a defective part with a new one. If it works, go for it...If not, you'll have to replace the coil...
Old 04-03-2006, 01:16 AM
vr6josh vr6josh is offline
I just rescently put new coils in my v-dub. It's an easy job but coils will go for $300 + because I found I had to buy the whole pack and that you can't just replace a cap like if it was a distributor. My advice would be to replace because the fix will probably just be temperary.
