| Off-Topic Talk about anything other than cars. |
hey guys hows it going, im new to the site, thought id ask ya all a question, well i own a 98 talon esi (non turbo) i recently put headers,high flow cat and cat back exhaust. Im about to order an AEM V2, i was wondering, do i really need a by pass valve? and id like to get some input as to what the next mod should be? and suggestions would be greatly apreciated
thanks |
Re: next mod?
Bypass valve...no, unless you drive eratically in large rain storms.
Next mod I would say would be a bored TB and upgrade the ignition. Also, do your maintenance and read the FAQ on this site.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: next mod?
sell it and buy a gsx or gs-t
Re: next mod?
hehe I thought you were getting some sort of engine management from AEM..I was like wtf?
yes, get the bypass valve, you never know when you might hit a decent sized puddle
now - 2000 civic soon - 2002 is300
Re: next mod?
Re: next mod?
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! |
Re: next mod?
Also, I just thought of another mod you can do that would free up a few ponies. Underdrive pulley.
Re: next mod?
Crank Pully is a huge must for N/As. Don't go cheap on it though.
The bored TB is a great mod. You will get power out of it, even with no other head work done. You just need a CAI for it to get some power. That bypass valve thing is useless. Don't get it unless you drive through pools of water. But it's your choice. Ignition is always easy to do. Pretty cheap too. This includes plugs, wires, and a coilpack. It's not much power, but everything will work together alittle better if there's more spark. And I agree with |_eclipse_|, get your maintence done and make sure that's all out of the way.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: next mod?
well thanks for the tips guys, ya i decided not to get the bypass valve, just went ahead and ordered the AEM v2, ill let you know how it works out looks to be a decent product, so for someone who cant bore out there own TB, relatively how much whould it cost for someone else to do it? and im thinking after that maybe some cams, does anyone know in ball park range how much they are?
Re: next mod?
I'm with crunchy on the bypass thing. It sure wont hurt to have it, but may hurt not to.
Re: next mod?
Whys does everyone jump straight to cams? lol. Cams are going to start at around $400.
TB porting can be done for about $50 with downtime, and I've seen places that have ones in stock. It was like $130 or something, then you send yours to them, and you get core money back. Search around. There should be a shop around by you that may do it anyway. You also really can't bore out your own TB. You can dremel out the inside to get it smooth, but that's really not giving anymore air flow. The best way is to get the hole TB bored at a size (say 55mm), and then get a new flapper made for it then also. Any place that'll do the boring will make the flapper too.
Re: next mod?
Edit: Boring the TB out will increase airflow, but more importantly, you will lose velocity if your TB is not matched to your engine's performance level. Here are some general numbers I found: Gary Howell wrote: "49mm TB flows 252 cfm 52mm TB flows 283 cfm 55mm TB flows 317 cfm 60mm TB flows 377 cfm At 8200 RPM a 122 cubic inch engine will need 290 cfm at 100% volumetric effiency, using the formula ((Max RPM/2)*Displacement)/1728. Rule of thumb is to go 10% over because a naturally aspirated engine can go above 100% volumetric efficiency because of cam overlap, header design, etc. Go above that and you kill low end because of reduced velocity, go below that you starve the engine for air at top end. 110% is volumetric efficiency is 319 cfm." "So a 2.0 turning 6500 rpm will require 229cfm plus the 10% which is 252cfm or a 49mm TB at the most. You already have a 52mm TB which is more than capable of providing the air your normally aspirated motor turning only 6500 rpm's will need. Again more reason to just smooth and speed the flow and not try to increase it the volume of it."
![]() 96 GST 5 spd.......(R.I.P.) smashed by a fallen tree 2001 Camaro SS 6 speed goodness! Last edited by SLoe; 03-12-2006 at 01:31 PM. |
