Battery cable corrosion
Hi, I have a 98 Suburban K1500, I noticed that on the positive terminal one of the battery cable connections corroded off completely. This isn't the main battery cable connection, but a thinner wire that's about 8 feet long and runs along the top of the fan and into the firewall on the driver's side and into the fuse box. Apparently I need to replace the wire since it looks like it's 1 long piece, but does anyone know if they make the aftermarket part or where to look? I called the dealer and they wanted $78 which I thought was a little high. Any suggestions?
Thanks |
Re: Battery cable corrosion
Go on E Bay and look for batery cables. My 97 Burb has gone thru sevral batteries, ALL leaking from the positive terminal??? I've only paid for one.... I keep buying the GM batteries at the dealer, and they have a replacement warranty. So when mine starts leaking, I return it for a new one at no charge.
Why GM can't fix the problem, I don't know. You should replace the cables, because the acid goes down thruogh insulator and just eats at the copper and you end up with less conductivity! |
The design that GM uses for it's battery cables is flawed. The best thing that you can do is convert your system to a top post terminal system, or use some type of lubricant to inhibit the corrosion. The corrosion can be a serious problem, the ABS system use in the Suburban takes a lot of power from the battery, I once had my engine died when stopping while the ABS was engaged. However, once I cleaned the terminals, the power-drain was much lower.
Good Luck |
