Old 03-10-2006, 05:22 PM
dwitczak dwitczak is offline
red coolant inside my blazer
I am getting the red coolant dripping (at a good rate) onto my passagener floor board.
I have a 96 blazer with 4.3.
6 months ago I replaced the heater core.
I just had the driverside head removed and a rocker replaced acouple days ago. they also did the distibbuter and spark plugs. could they have damaged something?
thanks for all your help.
Dan
Old 03-10-2006, 07:28 PM
old_master's Avatar
Advisor/Moderator
Re: red coolant inside my blazer
It's doubtful that they damaged the heater core. It is very well protected inside the heater case. The fact remains however, the heater core is the only component that can allow coolant to leak into the interior.
A very common cause of heater core failure is electrolysis. It is caused by poor, loose or missing ground connections, a lack of adequate cooling system service, inadequate or improper coolant properties. Test with the engine running at operating temperature. Make sure that all engine ground straps are in place. Using a digital voltmeter: Place the negative lead to the battery negative post and the positive lead into the coolant. A voltage reading above 0.3 volts can cause pinholes in the heater core.
Old 03-10-2006, 10:37 PM
blazee's Avatar
blazee blazee is offline
Problem?
A bad case of electrolysis can cause heater core failure in a matter of days. Your new heater core could have easily failed in 6 months.
Old 03-10-2006, 10:43 PM
old_master's Avatar
Advisor/Moderator
The same holds true with the radiator also.
Old 03-10-2006, 11:40 PM
OverBoardProject OverBoardProject is offline
Banned
I don't know how long I've been working on cars and never heard of that until today. Is it the same with the old green antifreeze?
Old 03-10-2006, 11:50 PM
blazee's Avatar
Problem?
It can occur with all antifreezes. Check out my posts in this thread if you want more info about it.:
http://www.automotiveforums.com/vbul...d.php?t=469926
Old 03-10-2006, 11:57 PM
Banned
Thanks Blazee, Although I doubt that I have a problem I'll check mine tomorrow to see what it sayes. I might be wrong but I believe that my 85 still has the origional heater core and it still blows enough heat to cook a meal on
Old 03-11-2006, 08:50 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Check your antifreeze, and remove unwanted hair ALL at the same time.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 03-11-2006, 09:40 AM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Bad Heater Core is causing the leak as Old Master stated. See my post in FAQ about Basic Coolant System Advice. But you can remove both heater hoses at the Firewall and jumper the two hoses together to buy you some time. You won't have heat, but you will be able to drive the Truck.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 03-11-2006, 09:49 AM
I FOUND THE PROBLEM. It must have been the recent mechanical work I had done. The bigger of the two coolant lines connected to the heater core was not connected, only butted up against. I connected it and no more leaks.
