Old 03-10-2006, 01:17 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Head Rebuild Questions
I finally got my new head in today (thanks Travis). Well, not new new, but the one I'm going to rebuild. I have a couple of questions now.
How can I clean it. I want every single little piece of that thing cleaned. I figured water is not good. Some kind of chemical bath? Soap and water?
Valves: I'm seeing standard size valves and oversized (1mm) valves. What do they mean by 1mm? I want to get the head port/polished, so would the 1mm be needed then or what?
Thanks!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-10-2006, 02:14 PM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: Head Rebuild Questions
The 1mm valves are if the valve seats get reground to a larger 1mm over stock. For just a basic port and polish you shouldn't need them because that is only going to effect your intake and exhaust ports. You should be able to use a carb and choke cleaner and some tooth or small wire brushes to clean the head up.
Hope that helps.
EDIT----> If you can afford it(I wouldn't think that it would cost much) you should have your intake and exhaust manifolds port matched to your head.
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
Old 03-10-2006, 04:26 PM
david-b's Avatar
Dave is THAT guy
I was going to port those out too. There's alot of downtime involved and I can't have that. I still got alot of time before this thing goes on anyways.
This thing is a mess... I need a lot of that stuff then. I mean it needs to soak good. lol.
So for just a basic port job, standard size is all I'm oging to need. I haven't had time to take aprt everything and see how the current valves are. I may just get OEMs and some better springs then. Anything else I should know?
75 Monte Carlo
Old 03-10-2006, 04:35 PM
SLoe's Avatar
SLoe SLoe is offline
^ For cleaning I use simming pool acid and a big ass garbage can for small engines and heads. Just be careful and don't get it in your eyes. Getting your parts tanked at the machine shop is not at all expensive though. I think it was $15 to do my small block chevy last time. Soap and water are OK too (just harder), just make sure it is absolutly dry after, and spray some WD 40 or similar on it.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
