Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-10-2006, 12:44 PM
projectgsr's Avatar
projectgsr projectgsr is offline
Valve adjustment
One more question. If I install aftermarket cams what all must I do? I'm assuming I'll first have to get them resurfaced or pollished right? And then once I do install them I'm sure I'll have to adjust my valve's. Can anybody tell me if this is all correct? I'm just figuring all this on what I know. Also if I do have to adjust my valve's I was wondering if anybody here know's how to do it themselves and is it fairly easy? Thanks.
JDM B18C, LSD tranny, Exedy flywheel/clutch, AEM intake, Greddy cat back, stainless header, Skunk2 manifold, Koyo radiator, Tokico Illumina full coilovers, black 17" Konig Hurry's, dc strut bars, custom cf hood, poly motor mounts, alum. battery bracket, b&m short shifter, Viper alarm, spoon chip, Tenzo R seats, Kenwood amp, Pioneer and MTX speakers w/cross over's, euro antenna, NGK wire's and plugs, Mobil 1 syn. and a whole lot of attitude.
9.4 sec 1/8 mile at Irwindale 4/20/06
Old 03-10-2006, 05:26 PM
hxgaser hxgaser is offline
Re: Valve adjustment
One you put in new cams, adjust the valves first without starting the car. See the following thread.
http://www.automotiveforums.com/vbul...d.php?t=526279
Of course set the clearance based on the manufacturer's recommended spec. Also don't forget to lube the lobes before putting in the new cams.
Then you should break in your cam. Start the car and immediately bring it up to 3000 rpm. Run it for 15 minutes at 3000 rpm. Be sure to keep an eye on the oil pressure and have someone standing by the engine to look for any signs of failure, such as any unusual knocking noise... That should do the trick.
You should recheck the valve clearances once more once the break-in is done.
Old 03-10-2006, 06:18 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
if they are new and not damaged, they do not need to be resurfaced and polished.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
