Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-10-2006, 12:35 PM
strap21061 strap21061 is offline
95 maxima air condition operation
Just bought a 1995 maxima. How do you turn on the A/C. It has the digital temp control. Thanks
Old 03-10-2006, 12:57 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 95 maxima air condition operation
Originally Posted by strap21061
Just bought a 1995 maxima. How do you ...
Maybe the Service manual has some info? Craig page has installation writeup for auto climate A/C... check out if it does contain operational info? Clic clic dig via 'Favorite Links', see below...
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 03-10-2006, 03:39 PM
bf_johnny bf_johnny is offline
Smile Re: 95 maxima air condition operation
I thing the only way you need to do is to set the temperature level at 50 to 60, then, the air conditioning will be on.
Old 03-10-2006, 09:06 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
set it on econ and turn the temp as low as it goes (65 i think in the 4th gen's). if you put it on auto the car is continually trying to maintain 65 degrees, if you put it to econ it will just blow cold air without trying to keep a constant temp.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 03-11-2006, 07:53 AM
I did this and I still did not get any cold air. I didn't even hear the compressor turn on, so I checked the R-134 w/ my gauge. It is low. I will buy a can and let you guys know what happened.
Old 03-11-2006, 08:32 AM
I did this and I still did not get any cold air. ...
Seems that the system doesnt work.
- test that compressor is wroking by hot wiring it to +12V [f.]
- check fan relays (3pcs) & compressor relay, clean contacts, replace if necessary [d.]
- check thermo amp closed [b.]
- check dual pressure sw at the liquid tank closed [c.] =enough liquid. When system is functional, coolant bubbling is seen through the sight glass.
The auto A/C -circuit has one temp sensor more than in this pic, ctrl panel different, check the links for more detailed info
http://www.cardomain.com/ride/748507/7
Old 03-19-2006, 09:16 PM
Found the AC Hi-Low pressure switch is bad. Need to locate a new one.
