Old 03-10-2006, 04:20 AM
JOE RILLA JOE RILLA is offline
Cool '05 Tail Lamps Into '00??
I was looking at a 2005 silverado and noticed that the bed /tailgate is exactly the same as my 2000. I was wondering if I could put the taillights from the '05 into my 2000?? I think the newer ones look better without the orange turn lens. Anybody know if this will work?
Old 03-10-2006, 10:28 AM
xpunter83 xpunter83 is offline
Re: '05 Tail Lamps Into '00??
yes you can I did it no problem almost direct swap. I just had to file a little part for it to work took 15 min looks 1000x better
Old 03-10-2006, 10:58 AM
Cool Re: '05 Tail Lamps Into '00??
wHAT DID YOU HAVE TO FILE??
Old 03-10-2006, 12:07 PM
i had to file a little part of one of the clips ( on the light socket) so it would fit in the new taillight
Old 03-10-2006, 01:28 PM
Nigel215's Avatar
Nigel215 Nigel215 is offline
you also gotta get/make a harnes to make the bottom blinkers work. if u want them to that is.
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 03-12-2006, 05:56 PM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
They will fit. You have to do some minor mods, and you can use the the factory '00 harnesses.
if you want more details, i can post tomrrow.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-13-2006, 07:46 AM
yES, THANKS, MORE DETAILS WOULD BE GREAT!!
Old 03-13-2006, 12:58 PM
jeverett's Avatar
The lights will bolt up with no problem. The only 2 setbacks you will have is a few the sockets onthe '00 harnesses will not fit. You will have to trim the inside of the light to get the bulb to fit. Minor work, very easy.
There is also an extra light on the 03 and up lights that you'll have to add to the '00 harnesses. There is a good write up on this, and this is actually the instructions I followed when I did this modification. It takes about 15 minutes and maybe $10 at most.
http://www.gmfullsize.com/forum/showthread.php?t=19481
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-13-2006, 01:29 PM
thanks, but that link doesn't seem to work.
Old 03-14-2006, 07:57 AM
jeverett's Avatar
Hmm, it works for me.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 03-14-2006, 11:42 AM
OK, once I registered for that forum it worked fine thanks!!
Old 03-14-2006, 12:50 PM
jeverett's Avatar
Sure man. Anytime.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
