Go Back   Automotive Forums Car Chat > Automotive Art > Sketching and Drawing
Old 03-09-2006, 09:39 PM
0tobe60in10minutes's Avatar
0tobe60in10minutes 0tobe60in10minutes is offline
Send a message via AIM to 0tobe60in10minutes
WIP silverado
hello peeps.
my name is alex and i am mainly familiar with the modeling forum, however i love drawing so i guess i will post from now on my drawings.
i just started a silverado truck, and i plan on spending a lot of time on this drawing (usually ill spend about 2 hours max on a drawing, so this will be a change-but hopefully will result in much better quality). leave comments, etc for advice if you would like.
i need to work on wheels btw...or better yet, elipses. l8r
RIP 88 Bronco II
Old 03-09-2006, 10:02 PM
stuffbyalex's Avatar
stuffbyalex stuffbyalex is offline
Re: WIP silverado
Good start. Looks good proportionally from what I can see!
Alex
www.geocities.com/stuffbyalex
Old 03-09-2006, 10:04 PM
jd_design's Avatar
jd_design jd_design is offline
Re: WIP silverado
yea its looks great especially the body....cant wait to see the end result
JD
Old 03-09-2006, 10:34 PM
Re: WIP silverado
thanks alex and jd!! ive actually found some time for drawing today so i have been working on this truck non stop. i usually like to critic myself hard, and so i can say the two front wheels look a bit awkward, but ill try and fix the few problems here in a while.
after i have to try and shade or color it... and im SCARED! i think im going to try the prismacolor pencils. do you guys have any tips?
RIP 88 Bronco II
Old 03-10-2006, 10:43 AM
jd_design's Avatar
Re: WIP silverado
well to tell you the truth i usually jus use regular pencils...and the second updated pic looks awesome krrp working on it!!!!
JD
Old 03-11-2006, 02:29 PM
Re: WIP silverado
ok i finished coloring/rendering with normal crayola colored pencils. there is alot of texture, and its evident. ill make a copy of the original and try stacking paper under my next attempt, if that helps.
i just went out and bought 12 prismacolored pencils, and now im broke , but ill see what happens next drawing.
thanx jd for the comment, its not perfect but thats fine, always room to imporve.
RIP 88 Bronco II
Old 03-12-2006, 03:58 AM
knightvision's Avatar
knightvision knightvision is offline
Send a message via ICQ to knightvision
Re: WIP silverado
Great work, öove to see the development of someone elses work. great perspectice, every line looks perfect, well maybe there's something wrong with the grill, but don't mind. the colors are a bit soft, I miss some contrast in it, somehow.
Maybe you try to put a few more layers on it, that could help. and to get rid of the texture, take a q-tip for each color and wipe and smudge on the colored area. this will get the color into the areas where is no color yet.
Great work, I can't wait for seeing next one!
todays MICE CINEMA:
Old 03-12-2006, 08:49 AM
Mshkttck's Avatar
Mshkttck Mshkttck is offline
Re: WIP silverado
It needs a bit more contrast in certain areas, but the perspectives are perfect.
mshkttck: you are a
mshkttck: LYER!!!
mshkttck: LIER!!
alex: liar?
mshkttck: LIAR, yes, thank you
alex: haha
alex: rofl
Old 03-12-2006, 04:36 PM
<<Si-Vtec>> <<Si-Vtec>> is offline
Send a message via MSN to <<Si-Vtec>>
Re: WIP silverado
i love it man !!!! but you could of made alot batter painting job then this...
Old 03-12-2006, 05:01 PM
PlayaC_inc.'s Avatar
PlayaC_inc. PlayaC_inc. is offline
Re: WIP silverado
looks awsome.but u could do a little better on the colors but other then that it looks great.keep up the good work. PlayaC
Old 03-12-2006, 07:15 PM
Re: WIP silverado
thanks for the comments everyone. i wish i was better at coloring, etc, but i shall give it another attmept tonight and see what happens.
im not sure if i should use the same color pencil, and just apply harder to the paper for darker spots, or use lighter shades for lighter areas?
RIP 88 Bronco II
Old 03-12-2006, 07:58 PM
jd_design's Avatar
Re: WIP silverado
i dunno but the way to find out is wat you are doing...jus try and try get it how you want it.......theres no better cure for an artists but something to work at.!!!
jd
