Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 03-09-2006, 07:19 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Angry Low Brake Fluid warning ?!?
Last week I changed the master cylinder on my 1991 98 TS. There's still a touch of air somewhere in one of the lines, but that doesn't concern me as my father-in-law, who's been a licensed mechanic the past 45 years says that'll eventually work it's way out. My concern is the Low Brake Fluid warning on the DIS. The master cylinder is full, but I'm wondering if it may have something to do with the rubber hose which carries brake fluid dowen to the ABS unit. Perhaps that unit needs to be bled separately? Any help would be appreciated as I just got the car, but don't have a manual yet. Thanks.
Tom
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 03-10-2006, 11:21 PM
Master01 Master01 is offline
Re: Low Brake Fluid warning ?!?
I am thinking that there might of been some kind of low fluid level sensor, that you might have disconected and might have to reconnect it. Look around it and see if there is anything you might of over looked. Also you might just want to finish bleeding out the air completely out of the system to be sure that it isn't a problem. You can also try to reset the cars computer, and see what happends.
Old 04-12-2006, 06:54 PM
Finally got to the bottom of the problem after waisting much time and brake fluid: not one, but two bad master cylinders from NAPA. Finally went to the wrecker and applied my 275lbs to the brake pedal of cars that had the same long master cylinder until a found one that didn't budge; brakes work great now!! NAPA price with my meagre discount CDN$150.00 + taxes, wrecker price CDN$15.00 + taxes. What a bargoon + didn't have to bench bleed and I now have a spare plastic resevoir in case one fatigues on me somehow!
