Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 03-09-2006, 06:10 PM
gumby_ct gumby_ct is offline
Gear Oil Discussion
Being the new owner of a 95 Tracker, I will be going right thru it. Likely starting with the transmission, since it is hard, well firm to shift. My new toy didn't come with an owner's manual and I have yet to find a repair manual for it.
Realizing the transfer case, rear & front axle also need gear oil, I thought I'd ask before I buy the wrong stuff. Do all of them use the same weight gear oil? I seem to recall SyncroMesh is recommended in the Geo Metro's transmission - is that also the case with the Tracker's? Would it be ok to also use SyncroMesh in the transfer case, front & rear axle? Or should I go to the dealer to get the GM recommended oil?
I hope to get to it by this Sat. so any thoughts are certainly appreciated.
Thanks,
Gumby_CT
1998 Chevy Tracker 4dr, 4wd, auto,
1996 2dr Metro LSi, 3Cyl. 5spd, 107k mi.
My other car...in need of repair it won't start any longer
1995 2dr Tracker Conv. 4wd, 5spd, A/C 170k mi. (My Fav)
Old 03-10-2006, 08:11 AM
viperh viperh is offline
Send a message via AIM to viperh Send a message via Yahoo to viperh
Re: Gear Oil Discussion
Thanks,
Gumby_CT
I use Mobile one gear oil Im all about synthetic.. However for your transmission don't use synthetic (synthetic is too slippery for most trannies). I forget what I had to use off the top of my head but it wasn't synchromesh but then again I have a '91 maybe someone else with your year can chime in.
Old 03-10-2006, 05:57 PM
This is the link from the Metro forum I was referring to
http://www.automotiveforums.com/vbul...ghlight=syncro
specifically the last post
75W90 is required, not Synchromesh. But what API Grade???
where he talks about viscosity, GL4 & possibly GL5 corroding synchros.
An earlier poster felt he ruined his transmission using the wrong gear oil.
I always thought gear oil was gear oil. As with ANY 4wd there is not just the tranny to consider
but the transfer case, front & rear axle too.
If they don't ALL take the same gear oil the problem is compounded.
Any thoughts or experience in the area would certainly be appreciated.
Thanks,
Gumby_CT
Old 03-10-2006, 09:23 PM
geofrog geofrog is offline
Send a message via MSN to geofrog Send a message via Yahoo to geofrog
Hello.
I had that done last year, tranny diff. and transfer case. changed it all with the recommended 80 90 gear lube.
