Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 03-09-2006, 03:48 PM
Cbierniat's Avatar
Cbierniat Cbierniat is offline
Unhappy 90 Seatbelts door ajar
My friend has a 90 tbird and the seat belts will not go back... the door ajar light is on and there is a constant beeping noise only when the headlights are on...it s very annoying cuz he got his radio stolen so that is all you hear lol...any clue what the problem is
Thanks
Old 03-09-2006, 08:56 PM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
Re: 90 Seatbelts door ajar
the connector in the door could be messed up, saying the door is always open.
My new RHD project!
Solid Crew (Circa 2002)
Old 03-10-2006, 10:46 AM
Cbierniat's Avatar
oh really so what does that mean
Old 03-10-2006, 10:49 PM
look in the door jam for a nob that goes in and out. Play with it, if it stops the door ajar stuff your good. If not it may need to be replaced or bypassed.
My new RHD project!
Old 03-11-2006, 04:26 AM
Cbierniat's Avatar
Yeah i fucked with the knob that goes in and out....the dome lieght and shit goes off door closed like it should....day or night....dont matter. ....so yeah any ideas...its reallllly annoying...
Old 03-11-2006, 07:13 PM
97Bird's Avatar
97Bird 97Bird is offline
Is the door adjusted so that the latch is fully closed when the door is shut? Try moving the striker out more to be sure the latch is fully closing. The "Door Ajar" and "Door Latch" switches are located at the latch of the door. You are playing with the courtesy light switch which is located in the pillar on the hinge side of the door. You have to remove the door panel to get to the switches and wiring. Ask at your library for the Mitchell electrical manual for your year car to see how the circuits are wired. Also, in a '97 both of these switch circuits plug into one connector under the left side of the dash. If this connector isn't plugged together it would give your symptoms. I don't know if this is true in your year car. That's why you need a wiring diagram for it.
The Original 97Bird
