Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-09-2006, 02:43 PM
idahonme idahonme is offline
Unhappy 99' Dodge Ram Oil Pressure when Pulling
I have a 1999 Dodge Ram, V-8, 5.2L, manual Transmission, 92K miles. I am having a problem with the oil pressure, it goes to zero when I am pulling something. It does not happen all the time and can be cleared by pulling over, turning off the engine and letting it set for just a little while and than starting it again. It will than be ok for a while or it may just go to zero again after a few miles. I have no problem with the oil pressure when not pulling, it stays steady all the time, no fluctuations or anything. Does anyone know what could be causing this? Thanks
Old 03-09-2006, 07:41 PM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: 99' Dodge Ram Oil Pressure when Pulling
Check your oil level, if you have a little too much, it will cause this problem. Had it happen to me, I was half a qt over and that happened, then I drained it and never had a problem since.
Old 03-09-2006, 08:50 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
When my truck did that it was engine sludge and the motor went.
My Mopars
Old 03-10-2006, 12:01 AM
dbfordtech dbfordtech is offline
I would hook up a master oil pressure gauge and drive. If you can, tee it in
with the factory gauge. This will let you know for sure if it is an engine problem or just a bad sensor/gauge.
Old 03-13-2006, 10:37 PM
did you find out what the problem was?
