Old 03-09-2006, 11:36 AM
jsledge's Avatar
jsledge jsledge is offline
Need to replace upper and lower ball joints
went to get the front end aligned on my 97' blazer at bell tire and they said I needed to replace the upper and lower ball joints on both sides...inner and outer ty-rods and shocks.
How hard is it to do the ball joints if I do it myself. never done it before. If it's easier to let a shop so it what is a good price.
thanks
Jim
Old 03-09-2006, 12:33 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Need to replace upper and lower ball joints
thanks
Jim
If you've never done it, it's quite the physical job. You need to drill out 3 rivets on each joint (These are good sized rivets that are usually torched out). After you're done, you'll require a front end alignment also.
Inserting the new joints are easier, but you might want to consider letting an independant mechanic do it. The Dealer will get about $600.00 minimum to do it. Ball joint run about $50.00 apiece, add about 3 hours labor for your total charges plus the alignment.
The '97s were recalled back around 1999/2000 for faulty upper ball joints, but I think that recall expired in the states back in 2004 (had a 7yr/70k mile expiration on it). But you may want to check with your local Chevy dealer to see if the recall is still valid, and if your truck had the recall done to it.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 03-09-2006, 02:55 PM
zachzchw zachzchw is offline
Send a message via AIM to zachzchw
I recently had to do all four ball joints, along with a pitman arm and an idler arm.
The ball joints were less than $20 each from autozone.
I had a shop do them, they only charged me $65. If theyve never been replaced, they will be quite difficult to get off, might want to have them done.
Old 03-09-2006, 03:48 PM
That's a pretty resonable price for labor, my local mechanic charges $60/hr, and as I said, this is a 2 to 3 hour job. I stupidly paid my local Chevy Dealer $325.00- 2 hours labor @ $100.00/hr, $125 for parts- to replace my lower units when I had it in for the recall on the upper units (I'll never go to the Dealer/Stealer again)
I just checked Autozone for ball joints, they're $31.00 apiece. Napa is $50.00 to $64.00 apiece depending on top or bottom, limited lifetime gaurantee on both.
Old 03-10-2006, 06:55 AM
Fractured1 Fractured1 is offline
if you gave a haynes or chilton manual and all the right tools, a little time to spare you should have no problem. I used a haynes maual, followed it to a T and was done within 4 hours for both sides. then get it alligned, you should be good to go.
Old 03-10-2006, 07:28 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
This is true. Pretty good instuctions in the manual. Time consuming but if youve got the time its not a bad thing to try to save some cash.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 03-10-2006, 08:38 AM
hunter01 hunter01 is offline
You could cut the rivets with a chisle also. Wear goggles
Old 03-10-2006, 01:01 PM
joeuser742 joeuser742 is offline
Yup, I cut my rivits off with a chisel. For me, it was alot easier than drilling them out. You need 2-3 bits, they wear down pretty quick. If you are changing all that stuff anyway, you might also want to change all the control arm bushings, they are probably worn and cracked; those are a real pain to get out, to do it right, you need a special tool to press them in and out. Actually you might want to see if a new upper and lower control arm comes with the bushings and ball joints, that might be the way to go if you want to do the work, it may even be a bit cheaper. Also take a look at the pitman and Idler arms, they were horrible on my truck.
1998 Blazer 4WD 4.3L 118,000miles 4dr
Repairs
--rear main seal, u/l ball joints, pitman/idler arms, i/o tie rod ends, control arm bushings, motor/trans mounts, oil relocation lines, door pin bushings, water pump, ring/pinion.
--Bad ABS ground, loose connection blower motor, repaired pulse board.
Mods/upgrades
-Throttle plate mod.
1999 Ford Windstar SE 3.8L 160,000miles
Repairs
--P171/P174 procedure, loaded control arms, tie rod ends, shocks, struts, springs.
Old 03-11-2006, 04:26 PM
When I did control arm bushings on another car I had I used an air chisle to remove the old bushings, clamped the control arm in a vise and then used a "cup" tool with a sledge hammer to put the new ones in. It's also a good idea to pre-load the suspension before tightening the bolts all the way.
