fuel guage points to fuel
ok here is the problem my fuel guage points allthe way over full to where it says fuel all the time before the guage was going kinda wacko it would not stay in one spot i want to make sure the sender is bad before i drop the tank to replace
and yes i am a ASE Master Auto Technician 1996 chevrolet silverado 5.7L 4x4 nothin but a k&n for now i just got it |
Re: fuel guage points to fuel
If it was going wacko before ya its probably the sending unit..........
I said probably, but I dont know of a way to test it or else I would of on mine to double check it
92 S10 Blazer Sport 4.3l Vortec V6 (W) 275,000 miles Jasper engine, Rebuilt tranny + rearend 04 Pontiac Grand Prix GT 43,000 miles |
check the ground wire on the sender unit it could be broke. i had that same problem on my blazer.
1999 k1500 350 hd tranny 8 inch lift 35" tires |
Check the wires outside of the tank real good.I replaced my sending unit and the gauge is still wacko.I gave up and just go by the tripometer
Sending unit is shot.
1995 Factory Blazer Service Manual for sale, PM if interested. |
If the sending unit loses ground, the dash gauge will register past "FULL". It could have lost ground in the sending unit itself, or anywhere from the connector at the sender to the ground on the frame. Either way you need to drop the tank to check for ground at the sender connector. If there is less than 5 ohms resistance, replace the sender.
My sending unit was erradict, sometimes reading full and then reading empty/ I call and got a price for it and was told I had to buy the fuel pump assembly. Well, my fuel pump worked fine. I couldn't see paying 300 dollars for the sending unit and pump. I dropped the tank and examined the sending unit. I saw the contacts where bent and made contact part of the time. I took the sending unit off and took it apart, and bent the contacts back, reassembled it and it works fine again, It wasn't that hard to do for me, I know the fuel pump will eventually go out on my truck. I felt it was a gamble, but being financially strapped, I took my chances. It's been two months and all is well. The sending
unit resistance is 250 OHMS, just in case any one needs to know that. SC ![]() ![]() ![]()
