Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-09-2006, 10:21 AM
warranty1 warranty1 is offline
not solenoid not starter
Dear folks,
I have a 93 Ranger (2.3L) and am having a very common problem posted in this forum. On the Ranger's 150k birthday, when turning the ignition key, I hear the click in the solenoid (but starter does not function). I replaced the starter 1000 miles ago. I just replaced the solenoid, and I still (often) just get the single click. It will eventually turnover after many turns of of the key. Ok, some facts:
1. new solenoid (and starter)
2. I am sure it is not the new rebuilt starter because I can jump the terminals and it will turnover (this is true for both the old solenoid and new solenoid).
3. The problem "seems" to be more common when the engine is hot (ie, park the truck for a short time after driving, and return to try to start).
4. Battery terminals were cleaned and well connected.
Most people that have responded in this forum to the exact problem have suggested a problem with main battery cables (corrosion, damaged, etc). Before I replace these cables, I would like to know whether this still could be the case for me considering the fact that I can jump the terminals on the solenoid and the starter will turnover with no problem.
So, my question is simple. Assuming my problem is with the battery cables, would it still be possible to start the truck by jumping the terminals (or does the solenoid require more power then would be required by simply jumping terminals)?
Or, if anybody as any other suggestions, I would greatly appreciated it.
Thanks so much!
Old 03-09-2006, 11:19 AM
12Ounce 12Ounce is offline
Re: not solenoid not starter
Sometimes these problems can only be found with voltmeter ... and the measurements must be made during high current draw, i.e., during cranking. This can make some measurements very difficult.
I once found the ground lead on the engine block, connected to a stud used for starter attachment, would rise more than 1/2 volt positive during cranking. It turned out that an anti-sieze material that used on the stud was acting as a partial insulator. The stud was removed and cleaned and a "whole heap" of electrical problems disappeared.
Old 03-09-2006, 12:34 PM
Psychopete Psychopete is offline
My firend has that problem with his 96 2.3L. He busted where the small wire runs to the starter. Not sure what, I didn't do it . It's only makes an intermittent connection and when he turns the key sometimes, all he gets is a single 'CLICK'. 'CLICK'ing it few times usually gets it working again. This does this hot or cold, so I am not sure if this is relevant. It's something to check out though.
Pete
