Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 03-09-2006, 06:55 AM
raymarquise raymarquise is offline
Remote Starter
My 95 has had this problem since I got it 3 months ago: Sometimes when I turn the key, nothing happens - like no power to the starter. However, if I use the power lock on the remote to unlock and lock the doors, then the starter will work. Yesterday I could not get the starter to turn over no matter what I did, so I used the remote starter. The engine started but with a whirring sound, sort of like the starter was still engaged. I used the key to try to switch the engine off, but could not - it kept running. This kept on for about 2 minutes then there was a big clunk and the engine died. I could not get it restarted. Finally I ran a wire from the starter so I could get + power to start, which worked, I could get it to run, but it would not start with the key. Last evening I turned the key, and surprise!! the starter engaged and the engine started as normal. Anyone has any ideas what's wrong?? Where is the remote starter unit located?? Can I disable it?? could it be getting stuck??
Thanks.
Old 03-09-2006, 09:00 AM
Pontiac94Transport Pontiac94Transport is offline
Re: Remote Starter
If your remote starter is factory installed. I'm not sure where it would be located. If it's a after market remote starter they are normally mounted under the dash on the drivers side. I'm almost 100% this information is as detailed as you wanted, but I wanted to share my thoughts.....
Old 03-12-2006, 01:55 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Remote Starter
Sounds like your starter itself is bad and not the remote start. All that a remote start does is mimic your key. Now, it could keep the starter engaged if it can't read a tach signal or if it was installed to use voltage sensing.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
