Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 03-09-2006, 05:13 AM
T66's Avatar
T66 T66 is offline
Turbo Oil
Hi guys. Please help me out. There is a little bit of oil on the inside (intake) of the compressor housing. If you take your finger and you wipe it then you see it. Why the oil? There is absolute minimal play on the shaft. (Turbo is a Mitsubishi TC06)
English is not my first Language.
Old 03-09-2006, 11:42 AM
SaabJohan SaabJohan is offline
Re: Turbo Oil
Does the oil come from the crankcase ventilation or from the turbo?
The seal at the compressor wheel won't give an absolute seal (unless you have a carbon seal which you most likely do not have). Small leaks may be possible under certain conditions especially if oil return flow is bad or the crankcase pressure is high.
Old 03-17-2006, 11:28 AM
doock87's Avatar
doock87 doock87 is offline
Send a message via AIM to doock87
Re: Turbo Oil
check on the compressor outlet for oil, not the inlet. if you're checking on the inlet, it's probably pcv. if it's on the outlet however, then i'm going to guess your turbo is dying. from the detail i can pick up here, i can't tell you much.
taaaaaaaaaaaaaaaaaaaaaaaaaaaaaaste....
