Old 03-08-2006, 10:33 PM
12field 12field is offline
driver side spark plugs
How to get to these plugs to change on a 1998 astro. Please help as I can not reach one. THANKS
Old 03-08-2006, 11:20 PM
astromonkey astromonkey is offline
Re: driver side spark plugs
Jack up the front driver side and remove the wheel. there is a access flap in the wheel well. Its best if you have a long 3/8 extension and a swivel
Old 03-09-2006, 05:05 AM
CD Smalley CD Smalley is offline
Taking the dog house off and working from inside will help on #5 too.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-09-2006, 04:29 PM
I did that but could not change spark or wire. Did you go thru the wheel well also as I did not try that. THANKS!
Old 03-09-2006, 07:31 PM
It's been a year since I did mine. I know I did go thru the wheel wells for some. Others I seem to recall actuallt getting under the van and doing them from the bottom.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 03-09-2006, 09:13 PM
dewaynep dewaynep is offline
Pull the wheel off and you can easily get to all of the spark plugs with a long extension and a u-joint. You don't need to pull the dog house.
Old 03-11-2006, 07:24 AM
THANK YOU!!!
Old 03-23-2006, 02:13 PM
fantastic's Avatar
fantastic fantastic is offline
Can the plugs come out without taking the heat sheilds off. I just went to change them on my work van and realized it is not as easy as 1, 2,...6. I looked from under the van when I went to do it.
Old 03-25-2006, 06:39 PM
You won't believe how easy it is if you just pull of the front wheels and use a long extension and u-joint. All you will need to do is hold the plastic splash guard out of the way. No need to pull off heat sheilds or the dog-house. It really is as easy as I say. Try it, you will like it.
