Old 03-08-2006, 09:13 PM
Tim Rif Tim Rif is offline
1989 Silverado K 3500
I need to replace the turn signal/cruise control unit from the steering column. Does anyone know the easiest way to do it? Thanks!
Old 03-08-2006, 09:57 PM
bigj-dog's Avatar
bigj-dog bigj-dog is offline
Re: 1989 Silverado K 3500
Are you referring to the turn signal/cruise control lever or the turn signal switch?
Old 03-08-2006, 11:04 PM
GOLIATHGMC GOLIATHGMC is offline
This is not a hard process, but it can be a frustrating one. Start by removing the steering wheel, then the black plastic cover, then the locking plate (bare with me, I am trying to do this from memory). At this point, you should be looking at the internals of the turn signal switch, which has 3 screws holding it in (you will have the move the lever one way or the other to access one of them). Before removing the screws, remove the turn signal lever itself - If I remember correctly, you have to push it in towards the column (along its own axis), then twist it gently (I dont remember which way). Now remove the 3 screws. Next, remove the 2 dash access plates under the column (1 plastic, 1 metal). The wires from the switch run inside the bottom of the column past the dash face, then come out through a black plastic sleeve. You can wiggle the switch harness to see which wires they are, then follow them to their connector further down on the column. Disconnect the harness (its a pain), then snake the harness up through the black plastic sleeve as you pull the switch assembly out of the column (be patient, its a REAL pain and its gonna fight with you). Reassembly is the reverse process. Any questions, feel free to ask - hope this helps!
George
REBEL Motorsports
Old 03-09-2006, 07:58 AM
Yes, I am referring to the turn signal / cruise lever.
Tim
Old 03-09-2006, 08:12 AM
bigj-dog's Avatar
GOLIATHGMC has got it. The only thing I would add is that I don't think you have to twist the lever before you pull it out. Just give it a good tug. Other than that, be patient.
Old 04-21-2011, 02:13 PM
ftn1975 ftn1975 is offline
reviving an old thread....
Is it possible to replace only the lever without removing the steering wheel?
Old 04-21-2011, 04:00 PM
ftn1975,
wow....quite a long time for this thread
No, I dont believe it is possible. Tearing the column down to that point is not hard, and I bet you will tear your hair out trying to mess with it otherwise. Not worth the effort to try to outsmart it IMHO.
Good Luck!
REBELMotorsports
'85 GMC K3500 CC/LB- SBC/TH400/NP205 -soon to be 12v Cummins/NV5600 "Miss Goliath"
'86 Dodge Daytona Turbo Z C/S
'84 Volvo 244GLT- 252K original miles - awaiting donor LT1 & T56
'90 Caprice 9C1
'79 Chevy K5 Blazer "The Beast"
'00 VW Golf TDI
HERS-'06 RAM 2500 CC/SB Cummins/Auto 4x4 Larimie (on order)
Old 04-21-2011, 05:44 PM
GOLIATHGMC,
looking at it closely, it seems it may be possible, but could do more harm than good trying. And yeah, could also lose allot of hair in the process. I will go ahead and pull the steering wheel. Should be much easier.
Thanks
