Go Back   Automotive Forums Car Chat > Ford > Contour
Old 03-08-2006, 08:58 PM
glasser3 glasser3 is offline
Send a message via AIM to glasser3 Send a message via MSN to glasser3 Send a message via Yahoo to glasser3
Exclamation need some help
alright well i have a few problems with my car the main one i have is my ac doesnt blow very cold and second the heat on my car has no happy medium its either too cold or too hot also i have a problem with my car idling too low and it does it even if its in park or in gear. another problem i have is my running lights only work when they feel like it does anyone know what maybe causing this i do know my cars wiring was hacked pretty baddly by a back yard mechanic so i suppose it could be a short somewhere but i dont know because they do work once in a while. is it possibly a fuse or something altho i have changed all the fuses in the car. Oh if anyone is wondering it is a 1998 ford contour sport with the 2.0 and a/t with overdrive altho my overdrive was also disconnected by someone also. if anyone knows where to buy parts too that would be great i need a drivers door skin, passenger side window motor, drivers side 4 way heated mirror, hood (was damaged in a hurricane in florida), one alloy rim and 2 center caps, also would like to get a new back seat it appears the one thats in it now was chewed by someones dog at some point, also would like replacement front seats carpet headliner and center part of dashboard (part around radio and ac and heat controls as it was damaged when someone stole my stereo). oh and does anyone know how to find out if the car came with keyless entry when new?
Old 03-09-2006, 04:57 AM
Jason43's Avatar
Jason43 Jason43 is offline
Re: need some help
AC: Sounds like it could use a recharge.
Heat: First things I'd check are the thermostat and the engine coolant level. Is the car running at proper temp?
Idle: Sounds like the IAC valve.
Just go to contour.org
1999 Ford Contour SVT
Old 03-09-2006, 09:59 AM
Re: need some help
well i should probally add that i already recharged the ac which didnt help much and another small part for the ac was changed but i cant remember right now what it was. coolant is at the right level and was just changed about 3 months ago and the car was running at the proper temp but i think my thermostat is starting to go im going to change it probally in the next week or so. wheres the IAC valve located and how hard is that to change?
Old 03-09-2006, 03:23 PM
Jason43's Avatar
Re: need some help
On the 2.0, no idea. I'd do a search for IAC in the Zetec Maintenance forum on contour.org. You'll find tons of info on it there.
Old 03-09-2006, 03:29 PM
Re: need some help
alright ill try and look on there altho ive looked for other things on contour.org and i find it some what hard to find what im looking for ... any other advice or ideas anyone has would also be great im starting to run out of ideas myself
Old 03-09-2006, 09:21 PM
Re: need some help
ok well ive tried looking on contour.org that site confuses the hell outa me but anyway if anyone has any idea where its at it would be great to know and also if anyone knows of any parts i could buy please lemme know my parts list keeps growing as i look deeper into the car
Old 03-12-2006, 07:56 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: need some help
The 98 Contour should have keyless entry if you have power locks.
You can confirm with a quick call to your local Ford dealership's parts department with your VIN number. If they check the VIN and you have Keyless Entry, all you need to do is add remotes to the system.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 03-12-2006, 08:01 PM
Re: need some help
ive actually had the vin run by 2 different places one told me i have it and the other told me i dont but i do have power locks
Old 03-12-2006, 08:03 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: need some help
all contours came with power locks.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-15-2006, 01:21 AM
Re: need some help
alright well a little update ... the car still has the problem with the ac and the thermostats been changed as well as the coolant ... the idle problem has been fixed though turned out it was a worn pully on the alternator ? anyway still workin on this car and i still need parts
