Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 03-08-2006, 06:25 PM
hoosierdaddy30 hoosierdaddy30 is offline
Send a message via Yahoo to hoosierdaddy30
Exclamation Dodge Spirit - no tach or speedo plz help
I had just bought a 1991 dodge spirit. The speedo and tach arent working. Replaced sensor on trans and didnt change nothing. I checked everything and even changed speedo tach assembly. Please give any suggestions. Thanks
Old 03-09-2006, 12:05 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
Re: Dodge Spirit - no tach or speedo plz help
Did you follow the speedo cable and make sure its not broken anywhere? Is there any loose connections around the distributor?
Old 03-09-2006, 08:07 PM
Thumbs down Re: Dodge Spirit - no tach or speedo plz help
i dont think theres a cable to speedo because the gauges are electric. I have checked plugs to are they are connected. because the radio doesnt work, i think its the ignition somewhere, does that sound about right, thank you for helping
Old 03-13-2006, 12:53 PM
ozzman87 ozzman87 is offline
not sure on the older cars but i sounds to me like the output speed sensor on the tranny although that should only affect your speedo. you tach should be hooked directly to you ignition control or the coil wire if it has a distributor. not too sure why both wouldn't be working.
