Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-08-2006, 07:07 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Bubbleling noise from inside the engine.
I was doing a boost leak test to see if I had more boost leaks, Well there is a boost leak coming from the throtle body, I have that gasket. When you take off the oil fill cap, you can hear the bubbeling noise coming form inside,What could that be?
The compression should good compression across the board. It sounds like there is a boost leak inside of head or something.....
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
