Go Back   Automotive Forums Car Chat > Buick > Century
Old 03-08-2006, 06:46 PM
jonsonton's Avatar
jonsonton jonsonton is offline
NO START: no spark
------It's an '87 century; automatic, 2.8 f.i.
O.K., here's the deal. It cranks normally, battery is good, good fuel pressure. I only checked one wire so far(#5), and I got no spark. I replaced the module 2 months ago when I was getting no spark from all the wires.
Could the module have shit itself in this short period of time?
Also, does anyone know which of the 3 connectors for the module supply the power and ground?
What else should I check? all fuses are good.
Old 03-15-2006, 07:21 PM
jonsonton's Avatar
Re: NO START: no spark
....Thanks for your help folks.
Old 03-15-2006, 07:25 PM
maxwedge maxwedge is online now
A990 racer
Try and get a scanner on it and see if you have cranking rpms if not, suspect crank sensor, ign module # 2 ,or even the pcm but less likely, check the connectors at the icm and the wiring to the crank sensor.
Old 03-19-2006, 11:52 PM
jonsonton's Avatar
I fixed it.....there was a build up of rust under the ignition module. I must not have cleaned it the last time I replaced it. Thanks for the help anyway.
jonsonton's Avatar
