How to remove a truck bed?
I need to replace my rear brakelines on my 90 2wd 2500. I hear the easiest way is to take the bed off. Any suggestions?
I don't have a lift but wondered if jackstands would hold it up. Also should I get replacement bolts before I start? How much does a bed weigh? Any other tidbits that would make this easier? Thanks, I really do appreciate tapping into the experience on this forum. |
Re: How to remove a truck bed?
You will need 4 strong backs.... There are 8 bolts that hold the bed to the frame, the taillight wiring needs to be unplugged, also all the bolts that hold the gas neck on and the grounding strap....then just pull it up and off.
Matthew Brough ![]() 1997 Geo Prizm -- 301,000 miles 2000 Honda Accord -- 225,000 miles 2004 GMC Yukon XL -- 223,000 miles 1987 Jeep Comanche -- 116,000 miles |
The bed weighs around 400to 500lbs.. I use a cherry picker to pull mine off.
It's a one man job that way.http://www.brutmfg.com/ |
And change the fuel sending unit while you're at it, beats pulling the tank out.
Get a look at the brake lines too
