Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-08-2006, 05:36 PM
pov02 pov02 is offline
Oil cooler?
Hi guys i was wondering if i need an oil cooler for my setup. I am kind of looking foward to buying one, but I don't really know if they make'em for 1992 GSX. I went to the junk and plucked off the whole oil cooler core, pipes and oil adapter (goes on the oil pump) from a 1990 or 1991 not so sure, but we had no way of figuring out what to do with it because its totally different. Well if any of you guys know where i can get an oil cooler setup or how to rig an oil cooler so it'll work for 1992. Please let me know, I have the following:
Engine:
HKS 264 272 camshafts
HKS camgears
JDM lifters
Crower Titanium Retainers and Springs
Ferrea Valves (1 mm over)
Port and Polished Head
Port and Polished stock intake manifold
Cometic Head Gasket
ARP Head Studs
JE Pistons (.02 over)
Eagle Rods w/ ARP rod bolts
Kings Main and Rod Bearings
Balanced Crank
Balance shaft removed
Following parts are new :
Block Freeze Plugs
Oil pump
Water pump
All timing and crank pulleys and belts
All gaskets and seals
Bolt-ons:
Slowboy FMIC w/ HKS BOV
GM MAFT
Polyuerthane Motor Mounts
Fluidyne Radiator
SPAL puller fan
RRE oil catch-can
FP 4" intake w/ K&N filter
60-1 T3/T4
Tial 38mm wastegate
Victory O2 housing
Apexi 3" downpipe
custum straight pipe through Apexi N1
ACT Streetlite Flywheel
ACT Extreme pressure plate 2600
ACT Street disc (hope but might burn)
TRE fully rebuilt with all of extra modification
with SPOOL instead of spider gears (busted and unreusable basket)
Fuel:
Walbro 255 lph
-6AN fuel line from tank to rail
Aeromotive rail
Aeromotive regulator
750cc RC injectors
Electrics:
PLX M-300 wideband
Dsmlink
MG ECU (don't really matter, but its new)
BR coil on plug
MSD Dis-2
NGK plugs
Old 03-08-2006, 06:01 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Oil cooler?
An oil cooler will help a good bit with a setup like that one. It shouldn't be too hard to rig up the oil coolers from the 90's and 91's to work on your 92. Just re-route your oil pump return line to your oil cooler and then have the oil cooler return line go back to the return line on your oil pump. There's no reason it shouldn't work. The only other problems I could think of that you may run into would be needing a little more oil in your system and you may run into a problem with low oil pressure. Just check to see if the oil pumps from the 90's and 91's are the same as in your 92. If so, then you should have no problem with oil pressure. You could also check and see if the oil capacity is the same as the 90's and 91's as in your 92. If so, then your home free and that should be all you need to do.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 03-08-2006, 07:51 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Oil cooler?
Yeah, I would definately use one reguardless of the mods. Not sure how to rig one up sorry, but you got it from a 90. They were the only year to get them .
EDIT: Also, I would image you'd take a good quart or quart and a half more with it, just be sure to watch it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 03-09-2006, 12:31 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Re: Oil cooler?
You could just get the 90 oil filter housing.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-09-2006, 02:55 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Oil cooler?
oil filter housing fome 90 will fit on any 6bolt engine. The 2g's need the evo filter housing to run extrnal cooling. If you have one, sell it, or use it. A good used 90 housing, lines & cooler can easly fetch $100
DSM geek
Old 03-09-2006, 07:25 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Oil cooler?
Yes, there is an EVO housing for the 2g motors. Several DSM vendors sell them (MachV, Turbotrix, etc). The only DSM in the US to come with an air to oil cooler (rather than the oil/coolant mixer) is the 90 turbo cars. THe lines and cooler itself can be used with the proper housing. You'll also need the banjo bolts and crush washers, which you may have snagged from that 90 car, or you can get them at the dealer.
Another thing many people do is get the filter housing and some metric to AN adapters, to run AN lines to an oil cooler of your choice.
Extra oil capacity required by the cooler setup will have no effect on pressure, extra oil capacity is always considered agood thing. Having to pump oil through a mildly restrictive oil cooler setup can drop pressure a little bit, but if it was a problem Mitsu would not have risked it and warranteed it. Also, for what it's worth, the EVO8s went back to the air style cooler, thank God! Those oil/coolant mixers are one of the unreliable parts on the DSMs, and I got rid of mine yeeeears ago...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 03-09-2006, 06:03 PM
Re: Oil cooler?
Hey guys, lets say i bought a summit oil cooler for example with Machv's external oil adapter. And i wanted to to run it with AN fittings and hoses, what size hose is recommended and if possible, about how long because i just want to mounted by the drivers fog light location, if possible (foglite is out)
