Old 03-08-2006, 01:54 PM
KTem's Avatar
KTem KTem is offline
cutting chrome parts off the sprue
How can I get chrome bits off the sprue without damaging the chrome? When I cut them off, the spot where the chrome part was attached to the sprue is not chromed, which looks bad. How to solve this?
Old 03-08-2006, 01:57 PM
rx7king's Avatar
rx7king rx7king is offline
Re: cutting chrome parts off the sprue
im pretty sure that is enevitable*, but what i do is just use the closest matching chrome paint i have and fill the spot, or strip the part after its cut off and spray the whole thing with chrome or silver paint
Old 03-08-2006, 03:08 PM
toyota00 toyota00 is offline
Ya, there isn't really a way to prevent it so you just gotta spray it with paint like the guy above me said...
Old 03-09-2006, 03:33 AM
deepraj deepraj is offline
Yes its pretty much inevitable, I try to minimise the amount to chrome lost by cutting the parts off carefully and not sanding them. I also use X-11 paint to try to cover the exposed area this is alot easier if the plastic underneath is a light colour (red is a nightmare to cover). Or you as the others have said you can strip the whole part using brake fluid and then respray it with a crome paint such as Alclad.
Deepraj
Old 03-09-2006, 03:52 AM
klutz_100's Avatar
I seem have to developed into an Alclad II addict of late however before that happened, I tried (successfully I think) to hide sprue removal scars with small bits of BMF. Blenede in better with the kit chrome IMO.
HTH
Old 03-09-2006, 04:11 AM
KTem's Avatar
Thanks all for replying. I don't have an airbrush, nor alclad, so I can't alclad those parts... Deepraj: I tried silver paint (TS30 spray, decanted) but colour-wise it differs too much from the chrome, so the "damage" is still visible. I can, however, put BMF on the parts to hide the blemishes! Thanks for that suggestion, Klutz! I'll give it a try.
