oil leaking
hi..i'm new, i have oil leaking from valve cover/spark plugs..haha..hard to explain..but when i pull the spark wire off, its all drentched with oil, and a metal tube comes up.., this is only on the right 2 sparkplugs..anyone know what to fix..or anything?.., friends suggested this is the best site to post up problems?..haha..2000 neon le..thanx
Re: oil leaking
Try searching a little bit. this was answered just a day or two ago.
Re: oil leaking
Your spark plug tube seals need to be replaced. You will have to pull the valve cover off to do this. It's a simple job and should only take you an hour at most. You will need to replace the valve cover gasket also, since you are breaking the seal.
Re: oil leaking
Where do you get these spark plug tube seals?
Re: oil leaking
Re: oil leaking
Re: oil leaking
well, what came in my kit, were a lot of little circular seals, then 4 spark plug tube seals, and the main valve cover gasket.., retail price was around $70 cdn.., but my buddies shop hooked me up a bit..lol
