Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-08-2006, 02:02 PM
95tahoe190k's Avatar
95tahoe190k 95tahoe190k is offline
95 tahoe 2dr sport4x4 191k
I have a heavy vibration problem when i come up to speed "30 to 40" mph then when i decellarate it gets worse and continues to vibrate to a stop , ive narrowed it down to the rearend , Damn sounds like a ring n pinion.I appreciate any info . anyone experience this or know what i can do to further diagnose this , im on a limited budget and its my only transportation. i put it in n, while driving 4 hi 4low no change ... ujoints are new wheels are new freshly rotated mounted and balanced. driveshaft has the weight on it the problem slowly increased within a week now its undriveable... hmmm maybe a wheel bearing. i dont know how to diagnose a wheel bearing i physicaly shake the wheel and there is no noticable play again any info will help .... thanks ... man 191k blah !!!!!!! HELP
Old 03-08-2006, 03:16 PM
Re: 95 tahoe 2dr sport4x4 191k
anyone have a parts list / parts price estimate on wheel bearings pinion bearings races, diff bearings ? im sure i can do the job, i wish i had an arbor press for the pinion bearing and crush washer. man i should pull the diff & check the ring gear .... and go from there man im getting my gear on its stupid cold out side.Ive never pulled axel bearings is there a special tool a 4ft fence pole lol or probly like a pigs foot pry bar...
Old 03-08-2006, 06:47 PM
777stickman 777stickman is offline
You say the u-joints are new, but check 'em anyway. Get all 4 wheels off the ground in nuetral and park brake off so there's no load on the driveshaft. Check the pinion shaft and the front yoke bushing for play. Ring and pinion going out makes a lot of noise as does the pinion bearing. While it's in the air start it and run it in Drive. Listen and look (but don't touch). If you've got a stethoscope, listen at the tx case also. Good luck and stay clear of anything moving!!..Steve PS: check the bolt torque on the driveshaft to pinion.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-09-2006, 09:32 PM
thanks 777stickman i havn't had time to look @ it once i find out what it is ill post my findings. thanks again
Old 03-16-2006, 05:41 PM
ok i got it up off the ground and the passenger drum is rubbing on the backing plate ... I need to find axel end play spec. i think the c-clips are shot . I also noticed in park off the ground the play when rotating the tires opposite ways then reverse the direction there was quite a bit of play, original limited slip diff might be tired . Hmmm what do i do next ...?do i drain it pull the c-clips and measure them .? funny thing is the vibration is undrivable but the wear on the edge of drum where it hits the backing plate is almost nonexistent
