Old 03-08-2006, 10:12 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
EGR Valve
Hi fellas, I'm getting a check engine light, took it to Auto Zone and the scanner came up with code P0401 which I understand is insufficient flow in the EGR valve. I have a 97 GP GT 3.8 110,600. What are my options to resolve this issue? Can I remove it and clean with carb cleaner? If yes is there a special technique in cleaning it? I was told that this part is quite expensive, around 160.00. Any suggestions will be helpful. Thanks again in advance...
Old 03-08-2006, 10:39 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: EGR Valve
Yes, just two 13mm nuts hold it on the flange. Just spray the spring loaded pintle with cleaner. However, do not move pintle. In the EGR pipe from exhaust to intake check for excess carbon and any obstruction. You should get a new gasket if EGR is removed.
A bad PCV valve and seal can cause DTC P0401 because the PCM uses MAP vacuum pressure to run the EGR flow test. Did you replace the PCV valve recently?
BTW - After spraying pintle let it dry and then spray with light coat of WD40.
Timeslip 08/12/06
AF Community Guidelines
Old 03-08-2006, 12:14 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: EGR Valve
Yeah, like Bob said
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-08-2006, 01:07 PM
Re: EGR Valve
Yea, I replaced the PCV along with the upper intake plenum manifold two weeks ago.
Old 03-08-2006, 01:48 PM
BNaylor's Avatar
Re: EGR Valve
Checkout the link below. The black o-ring on the PCV valve must be present along with the big orange one. Also, the MAP sensor holder must be tight and have the spring that fits over the PCV valve. MAP sensor must be locked down over the retainer pawls and properly connected electrically.
http://macgp.clubgp.com/howto/engine/pcv/gt/pcv.html
Timeslip 08/12/06
Old 03-08-2006, 03:31 PM
Re: EGR Valve
Thanks Guys, yes, I checked the PCV valve and there was no black o-ring so I took the black 0-ring off the old PCV and installed it. Hopefully this will take care of the problem.
Old 03-08-2006, 03:34 PM
richtazz's Avatar
Re: EGR Valve
Make sure you get the code cleared, and let us know if that fixed it. Just don't tell Bob he helped yet another person, it's going to his head, look at all those pretty pink stars!!! (just kidding of course Bob).
Old 03-08-2006, 03:40 PM
ern2112 ern2112 is offline
Re: EGR Valve
LOL...doesn't look like you are far off from being pink yourself Rich. Ho hum.....will take me a few more years to get there.....hehehehe. Course...I don't have that much info....so prolly will just have to start posting pictures of my car and dog to get there!
Old 03-08-2006, 03:41 PM
BNaylor's Avatar
Re: EGR Valve
Help which is mutual is a way of life on AF. But I sure enjoy helping people save money. Like being a good Samaritan.
Hey Rich, btw the stars s&$k. But you can change the title under the name. You think thats worth $50/year?
Timeslip 08/12/06
Old 03-08-2006, 04:04 PM
richtazz's Avatar
Re: EGR Valve
mmmmm........NO!!!!
Old 03-08-2006, 07:18 PM
Re: EGR Valve
I disconnected the battery for an hour and evidently that won't clear the codes on these cars. I went back to Auto Zone to have it scanned again and I was able to clear the code, the employees are not allowed. Anyway, the check engine light has not come back as of yet. Keeping my fingers crossed.
Thanks again for the excellent help
Old 03-08-2006, 08:12 PM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: EGR Valve
Ditto, especially the new gasket, make sure you have a new one before you take the EGR off. Worked for me.
