Trac Off and ABS light come on only during hard right corners at slow speeds. I think it's a wheel bearing. Which one? Are the bolts on the rear of the bearing tough to remove? How much dissassembly is required?
Re: Wheel Bearing Replacement
The hub/bearing can be done DIY in a few hours or less.
If it was your wheel bearing,you should hear a humming noise if you turn slightly too the right or left while going down the road doin 20-25 miles an hr or so..You might have rust-dirt on the abs ring.thats the part built onto the inside of hub assembly(bearing)....
I have a freind with a Snap-on scanner which can actually display wheel speed readings from each individual wheel (pretty sweet). Most DIY scan tools are not ABS capable. The ones that are cost $700+.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Yep, I'm looking for a used one myself (keeping an eye on e-bay). The flexibility and upgrades they offer are what have me wanting one. Luckily, I can borrow my buddies whenever i want.
If I had a $700 scanner, it would be worth more than my car. By the way, I'm going to put those bearings on tonight that I've had for the last two weeks. I've let fun get in the way of doing that job.
BTW - Personally I'd take a GM Tech II any day over the others. IMO, lots of GM dealerships will probably be going belly up all over the country so I'm keeping an eye out on EBay. Lots of money to be made on the side. Good luck on bearing job.
i have a 2001 gp gt and just had the same thing happen to mine. it ended up being the wheel sensor. which means your whole hub assembly needs replaced. found out the hard way that there is two versions of hub assemblies also. one has a steel sensor wire clip and mine had the plastic clip.
