Old 03-08-2006, 08:53 AM
zachzchw zachzchw is offline
Send a message via AIM to zachzchw
How to remove antenna base?
I have a 97, and am looking to upgrade the antenna. My old one is snapped off. How do I remove the old base?
Old 03-08-2006, 11:29 PM
Re: How to remove antenna base?
Anyone?
Old 03-08-2006, 11:32 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
I am not sure exactly but my guess would be it has to be done from inside the fender well. I am not for sure though never done it.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 03-09-2006, 12:11 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
the whole base or just the old rod?
Old 03-09-2006, 07:50 AM
billibong's Avatar
billibong billibong is offline
If it's just the roc, they screw off and screw back on. If it is the base it is removed by:
pull the mast and remove the capnut on the outside of the fender
unplug the antenna connector
Lift off the upper adapter and gasket
unscrew the assembly and remove from fender
pull the whole assembly up
Installation is reverse of removal.
Hope this helps.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 03-09-2006, 10:24 PM
BlazinMlew's Avatar
Hope this helps.
see it goes to show I dont know a damn thing
