Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 03-08-2006, 07:23 AM
jwat89crxsi jwat89crxsi is offline
new z car owner .... turbo?
i recently purchased a 89 300 zx na, i had all hondas before this car so im new to nissan, all i was wondering if anybody had some pointers to give me on making horsepower. turbo? and if turbo what would be a good place to start such a project?
Old 03-08-2006, 12:53 PM
AMNES's Avatar
AMNES AMNES is offline
Re: new z car owner .... turbo?
I suggest start turboing it on the exhaust headers. Thats under the hood
http://tuning18.c1.la
Old 03-08-2006, 06:08 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
well it depends on what you want to do.. are you looking for a car that gets good gas mileage, and still has some pep, or are you looking for a car in which gas mileage isn't as important as power...
If option one, get a big ol' cone style intake, a 2.5" exhaust with high flow cat, and Headers... if anything, headers are the single best mod you can do to an n/a car.
Now if you want option two, than turbo'ing the car is a MUST. I'd suggest finding a turbo engine and dropping it in. If you want good power, get yourself a 3"Downpipe-back exhaust with a 3" high flow cat, a big ass cone style intake, aftermarket boost gauge and boost controller, and raise the boost to around 8 PSI... you can go even higher if you add an intercooler...
It'd be better if you could give us more info on what you want to do...
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 03-18-2006, 08:41 AM
Kuntry_Boi06 Kuntry_Boi06 is offline
Send a message via AIM to Kuntry_Boi06 Send a message via Yahoo to Kuntry_Boi06
hey what do those stock engines take psi wise with the stock turbo's with low mileage on the engine?
I like my engine like i like my girls D's NOT B's!
"I'm not a ricer, i'm a RACER!!!" John D
89 supra N/A 5 speed... SOLD,
97 Neon.. broke down <-- typical dodge
94 300... under construction
Old 03-19-2006, 10:00 AM
^your question is too vague to give an answer... did you turbo and n/a engine or is a factory turbo engine... n/a's have a higher compression ratio, and therefore you can't boost as high without a few modifications. You really shouldn't boost above stock levels unless you have an intake, exhaust, and at least a downpipe (to be on the safe side). But you NEED to get an aftermarket boost gauge if you're going to be boosting.
Old 04-04-2006, 09:30 PM
stprasinz stprasinz is offline
ive ran 12 psi on a wore out turbo and a na motor with stock turbo cams
ive also ran 12 psi on a maxima head (same bottom end only a larger head chamber resulting in lower compression)
either set up was on a wore out motor (and wore out turbo) and both setups ran for about 4 months
and if your good an engine swap only takes 12 hours......
if your even better you can do it in under 4
get a new turbo (slightly larger than stock but keep the internal gat) with a maxima head and run 10 psi and youll be fine for a long time......
alkso get the intake and exhaust
or if you want to spend very little money just remove the ac, power steering and mechanicle fan(fan must be replaced by an electric) put the cone filter on it and an exhaust (if noithing else a muffler)
also the seats are pretty heavy go to your local speed shop and pick up some light weight buckets
and who need carpet thats what you got as house for isnt it
jsut to get your noodle working
oh and by the way you probably shouldnt listen to a word i say
Old 04-04-2006, 09:39 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
this guy sounds a lot like stephenp....
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 04-04-2006, 09:44 PM
you caught me, after all those years you finaaly caught me lol
yes thats me
hnmm never fuigued out my 300 problem so i got my 280 project going did you read the rebuild 280zx blah blah blah thread i posted
Old 04-04-2006, 10:08 PM
DeleriousZ's Avatar
skimmed over it lol
