engine turning over but wont start
hi there, i have a problem with my 1996 n reg laguna. out and about yesterday with no problem, however when i went to go back out last night the car started but the engine didnt rev properly, then it died!
the engine is turning, but it wont start, i even tried to jump start it from my wifes car but with no luck (clutching at straws). i have not had any problems up to now. any help would be appreciated. cheers jim |
Re: engine turning over but wont start
have u checked to see if ur spark plugs need replacing??
i had the same probelm on mine last month, bought a brand new battery but it still wouldnt kick, replaced the spark plugs and bang, starts 1st time! |
Hi,
Just cured a similar problem to yours. I was at a garage & stopped to fill up. Everything was fine until I went back to the car to drive away & it would'nt start. To anyone else out there the symptoms were as follows. Engine turned over but would not start or even fire. Checked for spark on one of the leads & nothing No Pulse on the Low Voltage side of the HT coils The car is a Renault Laguna 1997 RT Sport Engine is 1800cc with Distributorless Ingnition The Immobiliser Was Functioning Correctly, This can be verified by inserting the ignition key. If the little red light on the central locking button located by & just before the hand brake lever illuminates for 3 second and then goes out then everything is ok with the Central locking & immobiliser. Additional to this if there is a problem with the system then an amber light with a Zig/Zag symbol on the dash display will light and stay lit or flash. It will go out after a ferw seconds if all is ok. O.K The problem was a relay which is located underneath or close to the battery. Mine was underneath the coolant header tank. It is housed in a black plastic box and has two relay sockets, only one is used. This is the Ingnition/Immobiliser relay. If it has bad connections or in my case had quite simply popped out of the socket on one side then you will not be able to start the engine. Everything will seem ok apart from no spark/ignition If this is not your problem then try the crank sensor located on the left end of the cylinder head/camshaft cover. It is inserted into what would look like a distributor cap. Undo the Torx retaining screw and withdraw. These are pretty reliable but worth a look. Best Of Luck |
