Old 03-08-2006, 12:24 AM
jsledge's Avatar
jsledge jsledge is offline
97 Blazer goes click, click,click when I start it.
When I star my truck the engine has a repetitive clicking sound. after about 5 minutes it goes away...
The clicking is faster and slower with the RPMs
Thanks
Jim
Old 03-08-2006, 12:39 AM
Jeremy Fitch Jeremy Fitch is offline
Send a message via Yahoo to Jeremy Fitch
Re: 97 Blazer goes click, click,click when I start it.
Yes, a noisy lifter. What oil and filter are you using? How long has it been doing this?
1996 Blazer LT 4 Door, 4x4, 4.3L Vin W.
Old 03-08-2006, 12:54 AM
JC327's Avatar
JC327 JC327 is offline
I believe he means that the Blazer does actually start up, but has a "tapping" sound that goes along with the RPM's.
Sounds like a lifter to me. Are you by chance using a Fram oil filter?
Old 03-08-2006, 12:55 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I HATE the Fram brand name and anything with Fram on it....Cheap!!! I had a 99 Blazer that wouldn't accept fram oil filters. It liked those K&N filters, though...
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 03-08-2006, 01:00 AM
jsledge's Avatar
Just got the truck today, not sure what filter is on. Is a lifter something problem that can be correct without tearing into the engine...?
Old 03-08-2006, 01:04 AM
First, pull the dipstick and smell the oil. Does it smell like fuel?
Old 03-08-2006, 01:11 AM
jsledge's Avatar
pulled dipdtick, does not smell like fuel
Old 03-08-2006, 01:15 AM
Well there are a couple things you can try.
1. Make sure its got a good filter with a quality anti-drain back valve. This valve inside the filter will prevent the oil from draining from the top of your motor, where the lifters are, after the engine is shut off, resulting in better cold start oil flow. I perfer WIX or Napa Gold filters and have had execelent results with them.
2. Switch to synthetic or a better quality oil, this will sometimes make noisy lifters all quiet again.
3. Use one of the chemical engine flush products that clean the inside of the engine. Sludge and debris are one of the main causes of noisy lifters.
Old 03-08-2006, 04:53 AM
muddog321 muddog321 is offline
AF -Advisor
The High Mileage oil helps clean the engine, free sticky lifters, and also helps the seals - but how is the coolant level - this is one of those leaking intake gasket warnings as the Dex Cool sprays into the valley on the lifters so fill the overflow reservior and watch it - get a light and carefully look at the front corners of the intake and between the intake and valve covers for leaks/fluids. If you are near 100k it is due to happen and do not wait to fix it. When I did 2 of mine both showed orange Dex Cool in the valley.
Old 03-08-2006, 06:30 AM
jsledge's Avatar
Thanks to all those who helped
Old 03-08-2006, 10:27 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Oil filter or even a noisy fuel injector.
Can you record this sound?
Also, check what oil filter you have an let us know.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-08-2006, 11:55 AM
jsledge's Avatar
I changed the oil and filter and added some kind of thick 2 part goop for fixing noises and leaks and now it happens when I stard the truck and almost immediately stops....I'm gonna wait a few hours and let the engine get cold and start it and see how long it takes for the clicking to go away
Old 03-08-2006, 12:42 PM
BlazerLT's Avatar
AF -Advisor
Oh gawd, out of the pot and right into the fire.
Why the hell did you add that junk to your oil. Now you have completely counteracted doing the oil change seeing you now made the oil thicker and harder to flow on startup.
Don't add stuff to your oil unless you have doen your research on it.
