Old 03-07-2006, 05:29 PM
SBlazerNCS SBlazerNCS is offline
CPI nut kit question
has anyone thought about replacing the nut kit with regular high pressure fuel line of some sort? or is it even something possible to do?
Old 03-07-2006, 06:23 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: CPI nut kit question
It might be possiable but not practiable.
Start rigging it up and you may wind up with all kinds of problems
Just put on a new nut kit and be safe rather than sorry.
A new nut kit It should outlast the engine.
MT
MT
Old 03-07-2006, 08:33 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
10-4 on the No-Juryrigging. You're talking about the fuel system, squirting gasoline at 60 lbs. pressure. Don't take chances, fix it right.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 03-07-2006, 09:15 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
i actually did some juryriging during my nut kit replacement (really had no choice at the time). i replaced the cpi but i found the torx bolt on holding the nut kit was stripped out. after trying for 3hrs to get it off, i had run out of time for the day. i used liquid cement to patch the hole plus a piece of fuel hose over it with a hose clamp. this was a temoporary fix for just one day. the next day, i bought stud removers and was able to remove the torx bolt and replace the nut kit.
but yea i third the motion on no juryrigging, especially for a perminant solution, and as rick said gas is being pumped through those hoses at 60+ psi so do it right. new components, according to gm, should last 5-7 years.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 03-07-2006, 11:20 PM
i plan on actually buying the kit
i was just curious after looking at it if it had crossed anyones mind, im not very familiar with how the nut kit is put together
Old 03-08-2006, 08:59 AM
MT-2500's Avatar
AF - Advisor
When you get the old one off you can tell more about it.
They use the white farily hard plastic/nylon with a molded elbo tubing that slips on over a barb fitting.
The plastic tubing gets cooked by the heat inside the engine and cracks or gets a pin hole in it.
MT
MT
Old 03-08-2006, 06:31 PM
ive wondered why they didnt make that part out of hard line...i guess they werent thinkin ahead or there was some other reason....they all fail eventually for that reason
Old 03-08-2006, 06:58 PM
MT-2500's Avatar
AF - Advisor
Smile Re: CPI nut kit question
Well just think about it a minute.
How many engines did they make that uses that nut kit.
How many nut kits does GM OEM parts sell?
How many dollars do they make on each 75-85$ nut kit sale?
Say 50$ times how many kits they sell.
Does that not Add up into big bucks and into whos pocket?
And that is after they give you one of them Employee /family discount deals plus the no interest and easy payments.
Now ask yourself if they were not thinking ahead.
Do not kid yourself them engineers know how long that stuff is going to last.
And they have got it figured out much they can make off of replacement parts sales.
MT
MT
Old 03-08-2006, 07:12 PM
93LT 93LT is offline
If you are interested, you can view the photos I took of my injector and nut kit replacement here.
Rod
1995 K1500 Ext. Cab Stepside
1997 Olds Bravada AWD
2001 Silverado LT 2500HD CC 4WD
2001 Yukon SLT 4WD
Old 03-08-2006, 09:52 PM
hahaha mt-good point
and lt-ive been through that post many times, some of the best pictures of the assembly ive seen
Old 03-08-2006, 10:58 PM
SComp23 SComp23 is offline
Thumbs up Re: CPI nut kit question
That is honestly one of the best write-up's I have seen, great job.
Old 03-08-2006, 11:38 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
I'll second that
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 03-09-2006, 12:15 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
chassie, body, moter, there needs to be flex in the fuel line somewhere, that is the most practical place, make it out of hard line, and someone up here where i am will have a serious problem on a cold december morning
