Old 07-02-2002, 04:23 PM
Cackophony Cackophony is offline
Send a message via AIM to Cackophony
92 Civic Start Problems?!?
Recently my 92 Civic DX hatch has been having some trouble starting. It doesn't happen often just randomly every once in a while. When I try to start the car and I turn the key to "start" the engine seems to start, but when I turn the key back to "on" the engine dies. It does this a couple times then sometimes it just sits there and cranks, but never starts. It sorta reminds me of how my car would act if my car had no gas. Eventually if I just keep trying or let it sit for a second it starts up fine, and once it's started I have no trouble with it at all.
Does anyone have any idea what could be causing this? I've thought about taking my car into the shop for a tune-up, see if they could fix it. The only problem is that a tune-up usually costs around $400, so if anyone has any idea how I can fix this on my own that would be great. Thanks guys...
Old 07-03-2002, 07:12 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
first off, i dont know where you get your tune-ups done, but for 400 bux, i hope you are getting gold parts put into your car.
second your problem seems to be the fuel pump to me. i would check the flow rate on that first, before moving on.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-03-2002, 07:16 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Does the einge idle rough?
What RPM is it idling at?
it sounds to me that the car has some dirt build up inside the idle circuit that causes it to die after being started or not start at all while cranking.
If possible, check your fuel pressure (check it after the fuel filter first) to see if it's within spec (factory spec after the fuel filter should be 40-47 PSI).
If you have low fuel pressure after the filter, check it before the filter to find out if you have a stuck filter (I am not sure what is the spec before the filter, but I think it is somewhere between 70-90 PSI). Low fuel pressure can also cause these simptoms.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
